| Quinn Moore |
Oct 21 2026, 11:44 AM
Qmoore ![]() ![]() Group: Members Posts: 133 Joined: 13-July 21 From: Lake Geneva, WI Member No.: 25,718 Region Association: Upper MidWest
| friethmiller |
Oct 21 2026, 12:15 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,586 Joined: 10-February 19 From: Austin, TX Member No.: 22,863 Region Association: Southwest Region
| friethmiller |
Oct 21 2026, 12:24 PM
Confirmed Through-bolt. Here's mine.
![]() You're probably not going to like the answer to this question. I think you're going to have to pull all the pull rod tubes/ push rods, remove the tin on both sides so you can get at the bolt. Loosen it, apply thread sealant and then re-torque. Somebody else might have a better trick. Good Luck! (IMG:style_emoticons/default/blink.gif) |
| Shivers |
Oct 21 2026, 03:06 PM
Senior Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,680 Joined: 19-October 20 From: La Quinta, CA Member No.: 24,781 Region Association: Southern California |
First thing I would do is wipe off that oil and see if it comes back. Maybe I am losing it but I zoomed in and could not see oil on the washer or the sealant. It is just that is a lot of work and I do not see oil squeezing out from behind. Maybe look above first
| Quinn Moore |
Oct 21 2026, 03:11 PM
Confirmed Through-bolt. Here's mine. ![]() You're probably not going to like the answer to this question. I think you're going to have to pull all the pull rod tubes/ push rods, remove the tin on both sides so you can get at the bolt. Loosen it, apply thread sealant and then re-torque. Somebody else might have a better trick. Good Luck! (IMG:style_emoticons/default/blink.gif) Hey, thanks. You're right....I don't like it. But it needs to be fixed. Is that a crush washer behind a or the "regular" washer. Found this on pelican. Tried PET but was having a hard time locating that specific bolt configuration. If Im going in, I want to be ready with new washer/washers etc https://www.pelicanparts.com/More_Info/9011...-101-161-03-oem Thanks again. |
| friethmiller |
Oct 21 2026, 03:15 PM
First thing I would do is wipe off that oil and see if it comes back. Maybe I am losing it but I zoomed in and could not see oil on the washer or the sealant. It is just that is a lot of work and I do not see oil squeezing out from behind. Maybe look above first (IMG:style_emoticons/default/agree.gif) Also you might be able to get a wrench up there to try and tighten it, if that's the source of the leak. |
Lo-Fi Version | Time is now: 22nd October 2026 - 12:12 AM |
