| Literati914 |
Oct 30 2026, 09:16 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,402 Joined: 16-November 06 From: Dallas, TX Member No.: 7,222 Region Association: Southwest Region |
I have a passenger door/window (late scissor style actuator) that is fairly smooth when rolling the glass down until about the last inch or two, at which point it feels loose or like the glass drops down to it’s final resting position. I think I had this on one of my first 914s and just ignored it.. is there a fix?
| oakdalecurtis |
Oct 30 2026, 09:58 AM
Oakdalecurtis ![]() ![]() ![]() Group: Members Posts: 1,428 Joined: 5-June 15 From: Oakdale, Ca Member No.: 18,802 Region Association: Central California
I have a passenger door/window (late scissor style actuator) that is fairly smooth when rolling the glass down until about the last inch or two, at which point it feels loose or like the glass drops down to it’s final resting position. I think I had this on one of my first 914s and just ignored it.. is there a fix? Remove the door panel and observe what’s actually going on inside. That should point you toward the right fix… |
| Literati914 |
Oct 30 2026, 12:22 PM
..Remove the door panel and observe what’s actually going on inside. That should point you toward the right fix… yea the panel is off for refurbishment, and I can see the actuator tube... but I mean, it's a tube/loop, with the inner working mechanism facing away from view, so not much to see from simple observation at least. I'd hate to have to remove the entire thing, but maybe that's necessary(?) |
| mgphoto |
Oct 30 2026, 01:04 PM
"If there is a mistake it will find me" ![]() ![]() ![]() Group: Members Posts: 1,506 Joined: 1-April 09 From: Los Angeles, CA Member No.: 10,225 Region Association: Southern California |
..Remove the door panel and observe what’s actually going on inside. That should point you toward the right fix… yea the panel is off for refurbishment, and I can see the actuator tube... but I mean, it's a tube/loop, with the inner working mechanism facing away from view, so not much to see from simple observation at least. I'd hate to have to remove the entire thing, but maybe that's necessary(?) Ok confused, you say late scissor mechanism but then you say tube? If it is the early “tube” there is an adjustment on the bottom of the door about 1/3 from the front of the door. See the factory manual, there are directions on how to do it. |
| SirAndy |
Oct 30 2026, 04:53 PM
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 42,559 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
Sounds like the glass has separated from the lower channel. It's supposed to be held in place by the channel.
(IMG:style_emoticons/default/popcorn[1].gif) |
Lo-Fi Version | Time is now: 30th October 2026 - 10:07 PM |
