> Valve Adjustment with Chromoly Push Rods, Krusty's method
malcolm2
post Nov 2 2026, 05:31 PM
Prior to changing anything, I used Krusty's method and got my thinnest gauge. I found a 0.002....
I had rotated the engine around and checked my
1. Swivel Foot on each valve. They spin.
2. I also checked for any rocker movement... or really I kept rotating until i got a CLICK when i wiggled the rocker and spun the Swivel.
So at that point i was able to get the 0.002 gauge in. Remember, I am SHOOTING FOR ZERO LASH HERE
Should I try make that small adjustment so the 0.002 gauge won't go in?
KRUSTY'S Valve adjust method
GregAmy
post Nov 2 2026, 06:25 PM
My technique is the Krusty method, then slowly tightening the adjuster while moving the rockers up and down, to zero movement. Then I back it off like 1/16 a screw turn (just a touch) and tighten cause I figure when I tighten the nut it might follow it a little bit (despite a screwdriver to hold it in place).
It would be nice to know, theoretically, how much length those pushrods lose so I can have an idea if, for example, 5-thou too tight would be compensated.
But in the end, with a lift, a remote starter switch, and the Krusty method, it's not a time-consuming process at all so I do it regularly, like at each oil change.
Miss ya, Cap'n.
malcolm2
post Nov 2 2026, 08:15 PM
So you have never followed up with a gauge? You think 0.002 should be reduced?
I saw the note how the final tightening can reduce the last measured setting.
GregAmy
post Nov 2 2026, 08:33 PM
QUOTE(malcolm2 @ Nov 2 2026, 09:15 PM) *
I mean, it's "zero lash" right? How does one measure "zero"?
The implication of the stock parts is that the valve lash from cold reduces as the engine gets hotter; the system, primarily the pushrods, cylinder length, head height, reduce the valve lashlooseness as the system gets hotter. So the reason you sets the cold valve lash at a certain positive (loose) value is so the valve (primarily, the exhaust valves) don't go zero or negative "looseness" when everything warms up (a slightly held-open exhaust valve will quickly start to erode and burn up the edges/lips of the valve).
The implication of chromoly claim of "zero lash" pushrods is that as the engine warms up the total lash/looseness increases so that as long as you set it at zero or slightly more then the valves (again, primarily the exhaust) won't be partially open when fully warmed up. Of course the remaining stock system (rockers, valve shafts, etc) are the same but the pushrods are not increasing in length as much as the stock ones so "zero lash" is sufficient.
This is why modern hydraulic lifters are preferred, since they will, theoretically, compensate for these changes in block, cylinder, head, rocker expansion from cold to hot. Set and forget...no more regular valve adjustments.
Ishley
post Nov 2 2026, 08:58 PM
I set mine up to what is called loose zero. I Tighten until I can feel it just come down on the pushrod but I can still spin it with my fingers. After I lock the nut down, I check if it still spins and I try to move the rocker to see if I can hear it click/clack. Sometimes it takes several attempts If I don’t hear anything and I can still spin the rod with my fingers I know I’m there.
Works for me.
malcolm2
post Nov 3 2026, 07:55 AM
QUOTE(Ishley @ Nov 2 2026, 08:58 PM) *
Works for me.
Thanks.
My method has been similar. I just decided to try a tiny gage this time. I also read on here somewhere that loose is better than tight, so I’m shooting for zero and I get 0.002.
I might play around with one valve and see if I can get it where the 0.002 gage will not fit, but of course I get the swivel foot spin. Maybe I have a 0.001 gage somewhere.
Nogoodwithusernames
post Nov 3 2026, 11:21 AM
I've never had anything except aluminum pushrods myself, but I've always seen the "loose 0" method for chromoly. No feeler gauges, rocker should be touching, but should still be able to spin the pushrod.
The reasoning from what I've read, is because the chromoly has a very similar expansion rate to the steel cylinders, whereas aluminum pushrods expand more than the steel cylinders. Thus they need to be loose when cold or else they'll expand and hold the valves open when up to temp.
---edit--- All that to say, I think a 002 feeler is too much, but I don't think it would cause major harm. Mostly the motor will be a little noisier. It might increase wear on pushrod tips and rockers marginally, but that would be minimal, if any.
QUOTE(Ishley @ Nov 2 2026, 07:58 PM) *
Works for me.
mgphoto
post Nov 4 2026, 02:18 PM
"If there is a mistake it will find me"
Zero for me using the chrome moly push rods means the rocker arm doesn’t move when pushed and I can still rotate the elephant foot.
malcolm2
post Nov 5 2026, 12:01 PM
Found a 0.0015 feeler. So i used that just to make sure i wasn’t at 0.002. So they were about 0.002 for 4-ish years. I never checked before. So at least i feel closer to 0.
I lightly tightened with the 0.0015, checked the elephant foot for spin. Pulled the gage, tightened more with no screw driver.
Could not get the 0.0015 in and still had spin. Now i gotta put the exhaust back on.
malcolm2
post Nov 5 2026, 06:38 PM
Here we are.... 75 exhaust removed. Car raised HIGH, Wheel blocked... This is much better. high enough for the creeper is great. Might work on my position for the jack stands next time. But this was easy after the exhaust was gone.
GregAmy
post Nov 6 2026, 07:56 AM
QUOTE(malcolm2 @ Nov 5 2026, 07:38 PM) *
This, and the wheels turning free, makes life a lot easier...especially with the Krusty method.
https://www.napaonline.com/en/p/PTTW80586
Remember, Krusty means you don't have to be exact, you just have to be close...
VaccaRabite
post Nov 6 2026, 08:13 AM
En Garde!
Using feeler gauges to get zero clearance is way overkill.
Turn the adjuster till it makes contact. Tighten it down. Wiggle it. Any click? No? Good. Can you still spin the foot? Yes? Good. Done.
Are you hurting anything using a feeler? No. But you also aren't gaining anything.
Zach
iankarr
post Nov 6 2026, 10:21 PM
It's helpful if you use a sharpie to mark the chromoly pushrods. Then when you try to spin it with your (very cramped) fingers, you can easily see if it's moving, or if your fingers are just sliding on the PR
- Lo-Fi Version Time is now: 7th November 2026 - 08:18 AM
