| peteinjp |
Nov 3 2026, 05:13 AM
Member ![]() ![]() Group: Members Posts: 223 Joined: 15-July 21 From: Japan Member No.: 25,723 Region Association: None
I have the rear trailing arm off for replacement and looking at the oil tank.... the paint job was obviously not up for the task. The car only has a 4000 miles since this was installed new. Everything on this car (snoopy) was done with new and or original style parts so from a visual perspective it all looks original. But I just can't see how the steel tank wouldn't be better if it was aluminum. The filler neck is also a reproduction part and has tons of rust from condensation- surprising considering how much this stuff costs!
So- I'm on the fence- pull what I have and send it out for some type of 2 part epoxy treatment and get the filler neck cad plated, do my best with a wire brush and use some quality rubberized spray (not great for heat transfer- if that matters) or sell it and go all aluminum. Also seems like a good idea to get the chrome trim back on with the tank out.... Pete |
| mepstein |
Nov 3 2026, 06:44 AM
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,983 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region
The steel reproduction tanks don't have the copper coating like original. That being said, there are a lot of finishes that are more durable than the paint they used on the repro tanks. I would blast it and either powder coat, Cerikote or epoxy paint. Ben's/MB911 aluminum tanks are great but you would have to add a/n to metric adaptors to fit up to your existing lines
I would send to the filler for plating. I would also use a good dehumidifier in your garage. Snoopy is a great build. (IMG:style_emoticons/default/beerchug.gif) |
| bdstone914 |
Nov 3 2026, 08:01 AM
bdstone914 ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,422 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
If you go with one of Bens aluminum tanks get one soon as hemay not build more
| 930cabman |
Nov 3 2026, 08:53 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,878 Joined: 12-November 20 From: Buffalo Member No.: 24,877 Region Association: North East States
Depends on how married you are to originality, anything can be fixed, but from here a new aluminum tank would seem to be the EZ button
| Cairo94507 |
Nov 3 2026, 09:30 AM
Michael ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,798 Joined: 1-November 08 From: Auburn, CA Member No.: 9,712 Region Association: Northern California
An original tank has a lot of appeal; pull it and have it blasted and see if the inside can be treated to protect it and powder coat the outside. I would have the filler neck, dip stick, clamps, etc. re-plated and reinstall. Original tanks are hard to find. Love your build. (IMG:style_emoticons/default/beerchug.gif)
| Shivers |
Nov 3 2026, 09:48 AM
Senior Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,711 Joined: 19-October 20 From: La Quinta, CA Member No.: 24,781 Region Association: Southern California |
Hi Pete. (IMG:style_emoticons/default/bye1.gif) I know you've had this car a while. You live on an island, nothing you can do about that. But aluminum doesn't rust. MB911 is selling his oil tank stuff, and as I understand it will no longer be making them. I believe he is going to make something else.
So you may want to PM him and see what he can do for you. As for the stock stuff see if you can repair re-finish and store it away just in case you do decide to sell someday. Hope you are well. @peteinjp I just noticed his black friday thread http://www.914world.com/bbs2/index.php?showtopic=379508 |
| Root_Werks |
Nov 3 2026, 09:53 AM
Village Idiot ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,087 Joined: 25-May 04 From: About 15NM from Canada Member No.: 2,105 Region Association: Pacific Northwest
An original tank has a lot of appeal; pull it and have it blasted and see if the inside can be treated to protect it and powder coat the outside. I would have the filler neck, dip stick, clamps, etc. re-plated and reinstall. Original tanks are hard to find. Love your build. (IMG:style_emoticons/default/beerchug.gif) (IMG:style_emoticons/default/agree.gif) |
| rgalla9146 |
Nov 3 2026, 10:36 AM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,014 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None
Rust on the filler neck and the cap is very common. I've heard it said that starting and running only at times when full operating temp will be achieved will reduce condensation. Not too practical. I'd go with Marks suggestion. Also, keep an eye on the cap and replace or replate as necessary. Your rear hood hinge is missing the link that limits travel. |
| peteinjp |
Nov 3 2026, 06:07 PM
Lots of great feedback. I'm not really into adapters so I wrote Ben to see if he if metric is a possibility or not.
Leaning towards the aluminum tank for now and properly restoring the repro tank. I have to avoid mission creep. Right now the goal is to replace the dented trailing arm, get the re-restored PMB calipers on and get the brake system closed. Or I could leave the tank in and wait for phase 2 of the re-restoration where I drop the engine and address all the hard to reach areas, fix all the leaks, adjust teh valves, replace the flywheel and pressure plate etc etc. - that will probably be in a years time. Right now I just want to see the car back on the road because sitting around is the worst thing possible for all the systems- including the MFI. Is having the trailing arm off way easier in terms of getting the tank in and out?? It sure seems like it would be. Thx! P |
| Shivers |
Nov 3 2026, 07:13 PM
Lots of great feedback. I'm not really into adapters so I wrote Ben to see if he if metric is a possibility or not. Leaning towards the aluminum tank for now and properly restoring the repro tank. I have to avoid mission creep. Right now the goal is to replace the dented trailing arm, get the re-restored PMB calipers on and get the brake system closed. Or I could leave the tank in and wait for phase 2 of the re-restoration where I drop the engine and address all the hard to reach areas, fix all the leaks, adjust teh valves, replace the flywheel and pressure plate etc etc. - that will probably be in a years time. Right now I just want to see the car back on the road because sitting around is the worst thing possible for all the systems- including the MFI. Is having the trailing arm off way easier in terms of getting the tank in and out?? It sure seems like it would be. Thx! P Yes it is cavernous compared to with all that in the way. |
| mb911 |
Nov 3 2026, 08:32 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,832 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest
Lots of great feedback. I'm not really into adapters so I wrote Ben to see if he if metric is a possibility or not. Leaning towards the aluminum tank for now and properly restoring the repro tank. I have to avoid mission creep. Right now the goal is to replace the dented trailing arm, get the re-restored PMB calipers on and get the brake system closed. Or I could leave the tank in and wait for phase 2 of the re-restoration where I drop the engine and address all the hard to reach areas, fix all the leaks, adjust teh valves, replace the flywheel and pressure plate etc etc. - that will probably be in a years time. Right now I just want to see the car back on the road because sitting around is the worst thing possible for all the systems- including the MFI. Is having the trailing arm off way easier in terms of getting the tank in and out?? It sure seems like it would be. Thx! P Just to clarify 10 years ago when I started making tanks I adopted the 22mm mindset. All the aftermarket tanks are 22mm so that you can adapt to whatever you want as plenty of choices. If this is a real six then as stock tank should stay. Just my opinion |
| peteinjp |
Nov 4 2026, 01:37 AM
Not a real 6... but looks the part in most ways. Just what adapters are needed to stay with the original hoses?
Lo-Fi Version | Time is now: 7th November 2026 - 01:45 PM |
