> 73 2 liter PCV valve questions, Need some help on what parts are missing
Marcel Aircooled
post Nov 15 2026, 11:09 AM
Region Association: Europe
OK, I am trying to eliminate some possible air leak sources causing slightly higher rpm on my 1973-1974 2 liter 4 cylinder US GA code engine with D jetronic FI system.
Looking at the PCV valve I have and the Porsche parts diagram it looks like I am missing some parts. Mine is just screwed on with the white nut without any seal or o ring (#8 in below diagram) and the hose comming from the manifold is connected directly to the pcv without any elbow piece like #14 in the diagram. Also the stopper part (#9) is missing. Could the missing seal, elbow and/or stopper be causing a (small) air leak? My engine is running 100-150 rpm too high when idling and when I close the hose coming from the pcv with a pair of pliers the rpms drop to about 900.
Also my oil filler cap does not have any seal as shown in the diagram (bottom part of #2). Should there be a seal and if yes what type?
Here's a picture of the parts I have (white plastic nut is not shown)
And here's a screenshot of the Porsche parts diagram
and the part numbers
Thanks for reading and for any advise!
emerygt350
post Nov 15 2026, 12:08 PM
My 73 2.0 has a straight pcv valve which I think is normal. #12 in that diagram. An elbow of some sort maybe have been lost over the years, but I have not seen one on other active pcv cars. Later years went to a passive pcv so no valve and that same hose would just go to the cleaner box rather than the manifold.
It sounds like your PCV is working correctly if you are looking at a 150 rpm drop when you plug it. It was designed that way, it has little bleed passages that allow vapor to be pulled off the engine at idle, it doesn't really start pulling hard till the vacuum drops in the plenum when more gasses are expected to be produced.
I suspect your high idle is due to something else. Grab a can of carb cleaner and start spraying. Is your idle screw all the way in? If so, put your finger over the passage inside the throttle body that leads to that idle screw. Mine never seats completely and causes an idle bump (which I get by with just closing it completely which is probably the same as most people half turn open).
If your TB isn't leaking terribly at the butterfly bushings and your plenum seals are all good, and that elbow where the PCV hose connects to the plenum is good (check all that with the carb cleaner) then I would look towards your timing and temperature sensors.
Are you still using the original adv/retard distributor?
And yes, you do want that rubber gasket in the filler lid.
This one is from a 1.8
Marcel Aircooled
post Nov 15 2026, 02:03 PM
Thanks emerygt350, I don't see the elbow used much either when I search for PCV valve pictures. I have an electronic 123ignition so no original distributor anymore. I already replaced some hoses and had my MPS redone by Bosch and replaced the throttle body gasket which eliminated large part of the rpm issues. Idle screw is completely in like yours but does still show a gap where air passes. I have another TB with screw and it is the same so guess the screw never closes completely?
Will add a gasket to the oil filler cap. Do you know if there is a seal between the PCV valve and the filler housing?
emerygt350
post Nov 15 2026, 06:17 PM
I was hoping you had a 123 considering where you are.
The original setup resulted in an almost 10 degree retard at idle so I wouldn't worry too much about being 150 over. If I were you I would put my finger over the inlet in the tb to the idle circuit just to see how big of a leak that is.
I would then just use the 123 to lower the idle rpm. Stock, these motors would be at -2 or so advance at idle because of the retard. I suspect 6 or 5 would be the worst you would have to do.
At this point you will be able to do some experimenting to see if it is temperature sensor related. If you notice the idle drops way down when the motor is hot hot hot then that is a hint that your car is running in cold mode longer than it should. Do you have an air fuel ratio gauge? Have you confirmed your aux air regulator closes completely? I assume your motor is stock? The idea of even Bosch "rebuilding the mps" makes me cringe. If it isn't in the car, you really cant set it with any kind of hope to be dead on for something like idle. Not after 50 years.
JamesM
post Nov 15 2026, 10:00 PM
Missing the seal but I have seen that pretty often and doubt any leak would be substantial.
The 90 is just room for more leaks, which being on a manifold connected line is not good. Makes for more direct hose routing but because of the increased failure and/or people not wanting to source the part many have been eliminated.
Technically you are missing the hole plug as well but good luck finding a serviceable one of those. You can get some increased oil consumption, especially with high RPM driving when the hole in the underside of the oil tower below the valve is left open. but again, super common, most people have never even seen that part.
I would also guess that you are not getting proper retard at idle.
JamesM
post Nov 15 2026, 10:04 PM
QUOTE(emerygt350 @ Nov 15 2026, 11:08 AM) *
Never seen a 1.8 with that style.
1.8 L-jet cars had a different oil tower where a larger port comes off the tower itself at the oil filler cap directed into intake. The valve is integrated into the oil filler cap.
7 User(s) are reading this topic (6 Guests and 0 Anonymous Users)
1 Members: Marcel Aircooled
- Lo-Fi Version Time is now: 16th November 2026 - 12:40 AM
