> Questions on installing rear sway bar brackets
seanpaulmc
post Nov 15 2026, 05:05 PM
Hi World -
Looking for some advice from those who’ve gone before. TIA
I am beginning to plan installation of the rear sway bar brackets.
1. Should the bracket be bent to flatten against the trunk pan for welding? Same both sides of course.
I do not have the shock bolts in yet. One side is proving quite difficult to extract. I say this because of the next question.
2. Does the sway bar need to be mocked up (installed) to get alignment between each side, or is the alignment forgiving enough to eyeball?
Thank you
L-Jet914
post Nov 15 2026, 05:27 PM
QUOTE(seanpaulmc @ Nov 15 2026, 03:05 PM) *
Hi World -
Thank you
https://www.pelicanparts.com/techarticles/9...4_rear_sway.htm
Hope this helps. (IMG:style_emoticons/default/smile.gif)
bkrantz
post Nov 15 2026, 07:33 PM
I reinforced the inside of the rear floor panel above the location for the bracket.
bkrantz
post Nov 15 2026, 07:38 PM
Here is a shot from underneath. When I cut out the rear floor I left the brackets attached to the cross member.
Front yard mechanic
post Nov 15 2026, 09:35 PM
Mock it in place first. I drilled through the bracket and the floor put a small bolt then removed it after welding and welded the hole. That worked for me
- Lo-Fi Version Time is now: 16th November 2026 - 12:40 AM
