2 Pages V < 1 2
> Mechanically Freshening a '74 1.8
andrewvolsen
post Nov 20 2026, 12:30 PM
Post #21
The auxiliary electric fan and hoses were not installed on this car when I bought it, although I have a box of these parts. If I'm not getting enough heat without the aux fan, it will be a future project to install it.
I dropped off the heat exchangers at a weld shop to have the cracked mounting tabs repaired. The welder said he's going to laser weld them. I'll post pics of the results when I get them back.
andrewvolsen
post Nov 20 2026, 07:14 PM
Post #22
I adjusted the valves to .006 intake and .008 exhaust this afternoon. They were all tight before adjustment:
Cyl 1 - int: 0 ; exh: .005
Cyl 2 - int: .0015 ; exh: <.0015
Cyl 3 - int: <.0015 ; exh: .005
Cyl 4 - int: 0 ; exh: .005
I also removed the fan and fan housing and found that it had been assembled without the spacer behind the fan, causing the fan to rub on the housing.
2 Pages V < 1 2
- Lo-Fi Version Time is now: 24th November 2026 - 07:26 AM
