> 914 Jacking Points, Is there a conclusion to the discussions?
Highland
post Nov 16 2026, 03:12 PM
I've read all the threads and it seems like there will be an expert technique, then someone else chimes in and says it's wrong.
I'd like to know if I can lift the whole rear end with a jack under the engine bar and under the sub frame bar to lift the front end. I would of course use a wood block in between the jack and car then place supports under the "donuts".
rgalla9146
post Nov 16 2026, 04:47 PM
QUOTE(Highland @ Nov 16 2026, 04:12 PM) *
My car is low.
In the front I use a high quality, knot free 30" 2x4 between the front mounts
of the lower control arms. The board may flex up and touch the front of the pan.
I lift untill the front tires are off the ground then lower the car and switch to a
4x4 (which will now fit) for additional strength and lift.
An alternate method is to roll the front tires up onto short 2x4s
In the rear I place a 2x4 or 4x4 block under the rear of the transaxle.
Take care to avoid speedo cable and rear shifter attachments.
I've done this hundreds of times on hundresds of cars.
These methods are safe on flat, hard, smooth surfaces.
After lifting, strong, quality jackstands are manditory.
Root_Werks
post Nov 16 2026, 06:51 PM
Village Idiot
I'd pass using the engine bar to support a 914.
In the rear, I'll use the transmission (let the scolding begin). In the front span a 2x4 across A-arm mounts. Guess also depends what work is being done where and how you lift.
Haven't tried using a factory jack point off a Long in 40+ years.
Shivers
post Nov 16 2026, 07:34 PM
I use one of these and a floor jack over the seam on the bottom of the longs. Jack up one side and install my stands, then the same on the other. If I need it real high I alternate back and forth.
bkrantz
post Nov 16 2026, 08:16 PM
I also use the longs but my method is to use a piece of 1/2 by 2" hardwood about 18"long. I put this alongside the seam, plus a short length of 2x4 on the jack.
Once my car is jacked up I put jack stands under the donuts. I did put reinforcements on the floor pan to strengthen the donuts.
HansJan
post Nov 16 2026, 11:35 PM
Call me crazy.
I’m using the jack-points that Porsche put there for that purpose. Followed by placing stands underneath the donuts.
Works every time.
Ps: car is solid and door gap is not changing.
914werke
post Nov 16 2026, 11:55 PM
QUOTE(HansJan @ Nov 16 2026, 09:35 PM) *
Call me crazy.
Works every time.
You are, ...misinformed
The doughnuts ARENT Jack points. there were there as mounts for the carts used in the manufacturing line.
If you don't trust the integrity of the factory Long jack posts, use the pinch welds to raise & lower the car.
Superhawk996
post Nov 17 2026, 12:08 AM
QUOTE(Highland @ Nov 16 2026, 05:12 PM) *
And . . . You expected something different this time? (IMG:style_emoticons/default/poke.gif) (IMG:style_emoticons/default/lol-2.gif) (IMG:style_emoticons/default/stirthepot.gif) (IMG:style_emoticons/default/happy11.gif)
- Lo-Fi Version Time is now: 17th November 2026 - 02:23 AM
