2 Pages V < 1 2
> 914 Jacking Points, Is there a conclusion to the discussions?
Shivers
post Nov 21 2026, 06:31 AM
Post #21
QUOTE(jim_hoyland @ Nov 20 2026, 07:04 PM) *
QUOTE(FlacaProductions @ Nov 20 2026, 10:27 AM) *
can you show me a pic of where - exactly - you place this?
QUOTE(Shivers @ Nov 16 2026, 06:34 PM) *
I use one of these and a floor jack over the seam on the bottom of the longs. Jack up one side and install my stands, then the same on the other. If I need it real high I alternate back and forth.
Where can I find these?
Hi Jim link below.
Amazon
jim_hoyland
post Nov 21 2026, 05:11 PM
Post #22
Get that VIN ?
Thanks (IMG:style_emoticons/default/smile.gif) Ordered; is there anything Amazon doesn’t sell ?
worn
post Nov 21 2026, 06:18 PM
Post #23
QUOTE(Shivers @ Nov 16 2026, 05:34 PM) *
I have something similar. A hunk of wood with a groove cut for the pinch welds. Cut with a table saw, but there are other methods.
worn
post Nov 21 2026, 06:28 PM
Post #24
QUOTE(worn @ Nov 21 2026, 04:18 PM) *
We can count our blessings. A 914 isn’t a Lotus.
930cabman
post Nov 21 2026, 06:55 PM
Post #25
QUOTE(worn @ Nov 21 2026, 07:18 PM) *
(IMG:style_emoticons/default/agree.gif) super simple and great for all of us in the CSOB club
post Nov 21 2026, 08:20 PM
Post #26
914-6 GT in waiting
I once routed out some grooves in a hockey puck. Worked great.
Superhawk996
post Nov 22 2026, 04:16 PM
Post #27
QUOTE(mepstein @ Nov 21 2026, 10:20 PM) *
Commercially available in various types.
The one on the right works great on the jack pad.
The one on the left is to put on jack stand saddles so that you can use on a pinch weld without folding the weld.
There are also versions specifically for the recessed
BMW square shaped jack points
Highland
post Nov 22 2026, 07:02 PM
Post #28
So maybe a stupid question, but it seems best to support the car on the left and right of the pinch wild and not on the pinch weld itself. I assume this is true along the whole longitudinal.
Shivers
post Nov 23 2026, 08:38 AM
Post #29
QUOTE(Highland @ Nov 22 2026, 05:02 PM) *
Yes sir.
mlindner
post Nov 23 2026, 09:22 AM
Post #30
On my GT Tribute I use the front donut across to the pinch weld. On the back with the engine support beam gone.....the support is a great jack point, took the bolt out and then bolted a flat plate in on each side. Works great with out using the rear donut soft area.
DennisV
post Nov 23 2026, 11:53 AM
Post #31
This is true. The height of the sides of the adapter means the pinch weld doesn't make contact with the nylon and you get no benefit from the magnets. I just did this yesterday. I wasn't wild about it, but I lifted each side of the car (2 wheels in the air) at a time. It seemed fine. of course the integrity of your longitudinal will be a big factor.
I think the hockey puck could be a good idea, if you have a tool that will allow you to controllably notch that rubber and you don't mind spending the time.
Superhawk996
post Nov 23 2026, 12:12 PM
Post #32
QUOTE(DennisV @ Nov 23 2026, 01:53 PM) *
See post above - rubber pucks for pinch welds are commercially available as are many other types.
@DennisV
bkrantz
post Nov 23 2026, 09:09 PM
Post #33
QUOTE(DennisV @ Nov 23 2026, 11:53 AM) *
It may protect the pinch weld but IMO still a bit of a gamble. The short length of those adapters plus the uncertain integrity of the longs makes me cringe thinking about pressure points and local deformation. The metal version is worse.
2 Pages V < 1 2
- Lo-Fi Version Time is now: 24th November 2026 - 07:26 AM
