> 914World Classifieds Rules
> WTB: Adapter plate for engine and starter or bell housing, I'm building out my engine and want to test fire it on the stand.
GeorgeKopf
post Nov 17 2026, 08:14 PM
There are several ways to connect a type 4 engine to a standard engine stand. I've seen pictures of adapter rings that have a hole for mounting the starter. This would allow me to build the engine and get it running while on the stand.
Another option is to cut a bell housing from a compatible transmission. I'm hoping somebody has one lying around that they aren't using that I could buy, rent or borrow.
Thanks.
George
bdstone914
post Nov 18 2026, 02:36 AM
bdstone914
@GeorgeKopf
' date='Nov 17 2026, 08:14 PM' post='3278832']
Thanks.
George
[/quote]
I have a bell housing from a sportomatic that should work for you. I have always put the engines on the ground with a couple of 4 x 4s under the case.
Do you have a really solid engine stand? The bell housing will make for a lot of extended overhang weight.
- Lo-Fi Version Time is now: 18th November 2026 - 02:54 AM
