| DC_neun_vierzehn |
Nov 19 2026, 02:28 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 696 Joined: 16-November 20 From: Coastal Delaware Member No.: 24,893 Region Association: MidAtlantic Region
A new problem recently arose ... when I take my '73 (2.0 Dj-jet FI) out for a spin (cold start) it starts up fine and idles fine at 1,000 RPMs. Idle screw all the way in. I've had a 123 dizzy for a couple of years. 1,000 is the lowest I could ever get it to idle, but it's always idled steady at 1,000. No issues.
But now, I'll drive it for 10 mins on an open road then and come to a stop sign. When I come to a stop, the idle doesn't come down to 1,000. Instead it only drops to 2,000 RPMs and stays there at idle. Sometimes when I stop, it drops to 1,800 and idles there. Other times it's 1,600. It's different each time I stop, but usually in the 1,600 to 2,000 range. But while stopped, if put the car in 1st gear and let off the clutch a little to pull the RPMs down to 1,000 and then put it in neutral it will stay at 1,000 RPMs for idle as it should. Also odd is that if I drive the car for 30, minutes or 45 minutes or an hour and turn the car off to run into a store for 5 minutes, when I start the car back up (hot start) and drive it, the idle issue will sometimes go away. In fact, sometimes it will idle at 800 in those instances. It's driving me crazy. I performed a smoke test. No vacuum leaks. I had a NOS decel value and put that on. Made no difference. FYI the has a Bowlsby FI harness and a Bowlsby rebuilt MPS. But those parts have been on the car for a couple of years now. What could be causing the idle issues? |
| JamesM |
Nov 19 2026, 03:00 PM
Caretaker of 914s - Master of Fuel Injection ![]() ![]() ![]() ![]() Group: Members Posts: 2,366 Joined: 6-April 06 From: Kearns, UT Member No.: 5,834 Region Association: Intermountain Region |
Are you using vacuum retard on the 123?
It could be that your advance curve is to aggressive. That is usually what I find when loading it up restores proper idle. Could have a sticking/bad/slow AAR contributing as well Pull the air line to your AAR and put your thumb over it when its acting up and see if you are still sucking air there. |
| ctc911ctc |
Nov 19 2026, 03:13 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,396 Joined: 9-June 18 From: boston Member No.: 22,206 Region Association: North East States
Are you using vacuum retard on the 123? It could be that your advance curve is to aggressive. That is usually what I find when loading it up restores proper idle. Could have a sticking/bad/slow AAR contributing as well Pull the air line to your AAR and put your thumb over it when its acting up and see if you are still sucking air there. (IMG:style_emoticons/default/agree.gif) (IMG:style_emoticons/default/agree.gif) (IMG:style_emoticons/default/agree.gif) |
| Tom_in_NH |
Nov 19 2026, 05:39 PM
Newbie ![]() Group: Members Posts: 24 Joined: 21-August 22 From: FL Member No.: 26,792 Region Association: None |
Could be the decel valve sticking open. Also, the fact that it idles at 1000 rpm with the idle screw all the way in, indicates other issues, such as an inop idle control valve.
Lo-Fi Version | Time is now: 19th November 2026 - 08:25 PM |
