| Boothy |
Nov 22 2026, 08:28 AM
Member ![]() ![]() Group: Members Posts: 114 Joined: 17-January 19 From: Abington, MA Member No.: 22,805 Region Association: North East States |
Cheers All,
Corrected my rich problem last spring where I re-jetted and it was too rich so it smoked a lot. It's cleaned out now but it still revs high when driving. Sitting it will idle comfortably at 1000. And when I lay on the the throttle is goes nicely. But when I let off it's reving high. I'm thinking I need to drop the idle jet but advice will be appreciated. 1700 punched out to 2000. Weber 40s. 123 Ignition. Heavy springs on the linkage. Thanks in advance! |
| emerygt350 |
Nov 22 2026, 10:59 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,835 Joined: 20-July 21 From: Upstate, NY Member No.: 25,740 Region Association: North East States |
Is the 123 Bluetooth? If it is how abrupt is the curve in the 123? Checked for vacuum leaks? Not much of a carb person but vacuum leaks are always possible...
Lo-Fi Version | Time is now: 22nd November 2026 - 12:03 PM |
