> I have two 4 cylinder engine cases ..., What would you do?
GeorgeKopf
post Nov 24 2026, 09:03 PM
I have a WO engine case and an EA engine case.
I also have:
a set of weber dual 40mm carburetors
a pair of stainless steel 2.0 heat exchangers
a pair of stock 2.0 heads
All of the rest of my engine components are from a 1.7 liter (crank, cam, pistons and rods)
I want to keep the factory heat exchangers so that I can have cabin heat.
I could build the EA case to be a naturally aspirated 2056.
I could build the WO case to be a fuel injected 2270.
Either way, I need to buy a new crank, cam, rods and pistons.
I understand that the 2270 will be hobbled by the stock heat exchangers, but I also believe that it will have more torque making the car more responsive.
I could build the 2056 first, get the car on the road and then worry about the 2270 if I think it necessary.
I'm not looking for a definitive answer. I'm just soliciting the communities expert opinions and hoping to have a conversation.
Thanks.
George
Superhawk996
post Nov 24 2026, 11:44 PM
QUOTE(GeorgeKopf @ Nov 24 2026, 11:03 PM) *
I think you probably need to resolve what your expectations are.
In either engine instance - you’ll still be slower 0-60 than a 2026 Toyota Camry. The 2270 might get you on par depending on cam, headwork, but probably not on stock heat exchanger exhaust.
914’s are momentum cars no matter which way you slice it . . . Always have been . . . Always will be. If the goal is to be fast you need to be fast in the corners. Neither of those engines will be fast in a straight line.
If the goal is to simply enjoy the car for what it is, a snapshot of history and enjoy an analog experience that is impossible to find in a modern car, either of those engines will get the job done. Then it just comes down to how much do you want to spend to go X% faster off the line.
Just a perspective to consider.
Shivers
post Nov 25 2026, 04:11 AM
Hahaha, you’ll get a lot of opinions. This is mine. They are both early cases. I have heard that the construction of the early cases is stronger around the spigots. But like the rest they are old. So my suggestion would be send them both to your machinist and have him check the line bore, the spigot decks and lifter bores. My first engine I build was a 1911, 66x96. I did some head work on the 1.7 heads, IDF 40’s and a good cam and it rev’d to about 6k. It was tough and it was a runner. My last build Was a counter balanced 2.0 crank, rods and P&C’s. Maybe a little more hp but I still kind of wish I had kept the 66 crank and counterbalanced one. Larger main bearings on the 1.7. A good set of rods and 100 P&C’s you end up with a 2074.
post Nov 25 2026, 06:00 AM
914-6 GT in waiting
I think when you add 40+ hp, it really transforms the car. It's still not "fast" but it sure feels better in traffic and gives it some zing when you are exiting a corner.
You can always build the "cheap" engine to get it on the road and then build the big engine while you enjoy the car. Every engine you build will help you with the next one.
rick 918-S
post Nov 25 2026, 06:19 AM
Hey nice rack! -Celette
Here's another opinion. I like increase the compression and lighten the flywheel. It increases the throttle response. You are still likely not going to the drag strip and depending on your engine you have to modulate the throttle because you can end up with a stall condition. But 7 of 9 had a faster throttle response with stock FI and would out run the new owners stock 6 in the corners.
OrangeBones
post Nov 25 2026, 10:02 AM
Build the 2056, it doesn’t disappoint! Then make plans to join us for the Northeast Gathering with a running driving car. Nothing like a deadline to get motivated.
quote name='GeorgeKopf' date='Nov 24 2026, 11:03 PM' post='3279626']
I also have:
Thanks.
George
[/quote]
post Nov 25 2026, 12:32 PM
Resident German
QUOTE(GeorgeKopf @ Nov 24 2026, 07:03 PM) *
Weld them together and make a flat /8 ...
(IMG:style_emoticons/default/w00t.gif)
GeorgeKopf
post Nov 25 2026, 12:55 PM
QUOTE(SirAndy @ Nov 25 2026, 01:32 PM) *
@SirAndy
This made me laugh out loud.
George
GeorgeKopf
post Nov 25 2026, 01:05 PM
Thank you everybody. All of your opinions are cherished and helping me make a decision.
Can you recommend a company that should I send the cases and heads to for inspection and any necessary machining.
Jake Raby has a video where he explains that he cuts grooves in the case to allow oil to flow and prevent rear main seal leaks. https://www.youtube.com/watch?v=siPS_EBLxLY (timestamp: 11:50) I would like this modification made to my cases.
Thanks
George
930cabman
post Nov 25 2026, 03:50 PM
I like my 2056, straightforward, nothing crazy, mostly simple and pulls decently. She has 3 years and about 15k miles with twin 40 IDF carbs and cabin heat
6 User(s) are reading this topic (3 Guests and 0 Anonymous Users)
3 Members: dtmehall, tygaboy, SirAndy
- Lo-Fi Version Time is now: 25th November 2026 - 05:13 PM
