| 914rrr |
Nov 24 2026, 11:25 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,137 Joined: 1-July 03 From: McMinnville, TN Member No.: 874 Region Association: South East States |
What bulbs have you guys had good or bad luck with?
| barefoot |
Nov 25 2026, 10:21 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,576 Joined: 19-March 13 From: Charleston SC Member No.: 15,673 Region Association: South East States
Used these in gauge cluster & small bulbs in rear turn signals
Think i got them on Amazon BTW they're dimmable Worked fine. ![]() There are 4 different bulb holders in gauges, 2 body ground & 2 separate ground ![]() |
| 914rrr |
Nov 25 2026, 12:54 PM
Used these in gauge cluster & small bulbs in rear turn signals Think i got them on Amazon BTW they're dimmable Worked fine. ![]() There are 4 different bulb holders in gauges, 2 body ground & 2 separate ground ![]() Thanks, I'm actually looking for the torpedo(?) shaped bulb that goes into the interior light that's mounted in the back pad. IIRC, if you get one that's too high wattage it will melt the fixture / lens. |
| rgalla9146 |
Nov 25 2026, 04:14 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,035 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None
oops.
Attached thumbnail(s) |
| rgalla9146 |
Nov 25 2026, 04:29 PM
Osram K6518 12V 10W
The wattage is stamped into a spade connector that gets a ground wire The red wire connects to the single spade opposite. No matter what bulb you get it is better to leave the switch in the off position. If left to operate with the doors you risk damage by leaving it on too long with a door open (IMG:style_emoticons/default/sad.gif) Mount the lamp with access to both the front and the back of the pad to avoid frustration and damage |
Lo-Fi Version | Time is now: 25th November 2026 - 05:13 PM |
