| Jon H. |
Nov 27 2026, 07:58 AM
Member ![]() ![]() Group: Members Posts: 243 Joined: 1-July 11 From: Ottawa, Canada Member No.: 13,264 Region Association: Canada |
Hey fellow teeners. After 15 years I'm finally getting some progress on my 914-6. I got a 2.4L back in the spring and hopefully this weekend I can get it installed. But I'm not sure how to proceed. I have the Maddog 914-6 engine mount. I have the instructions with the measurements but I'm not sure if I have to first bolt it on to the firewall and then install the engine/tranny to check for fitment (not even sure what I would be checking). Then if all is good, remove engine/tranny and weld the mount to the firewall. Or do I just bolt it in using the measurements in the instructions and weld it and hope for the best?
Regards, Jon h. |
| sixnotfour |
Nov 27 2026, 08:08 AM
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 11,449 Joined: 12-September 04 Member No.: 2,744 Region Association: NineFourteenerVille
15 yrs ?? What version do you have ?? there is a kit someone made and its lower for racing,,Hope you dont have that one... Pics are 1000 words.. Good Luck sixnotfour
| mate914 |
Nov 27 2026, 08:33 AM
Matt ![]() ![]() ![]() Group: Members Posts: 954 Joined: 27-February 09 From: Eagles mere, PA Member No.: 10,102 Region Association: North East States
Hey fellow teeners. After 15 years I'm finally getting some progress on my 914-6. I got a 2.4L back in the spring and hopefully this weekend I can get it installed. But I'm not sure how to proceed. I have the Maddog 914-6 engine mount. I have the instructions with the measurements but I'm not sure if I have to first bolt it on to the firewall and then install the engine/tranny to check for fitment (not even sure what I would be checking). Then if all is good, remove engine/tranny and weld the mount to the firewall. Or do I just bolt it in using the measurements in the instructions and weld it and hope for the best? Regards, Jon h. If it sits to high or low, your engine seal wont ling up and your lid will not close.... |
Lo-Fi Version | Time is now: 27th November 2026 - 11:19 AM |
