> Column Ignition Removal
friethmiller
post Nov 27 2026, 11:35 AM
How does one get this thing out (yellow arrow)? I know that actuating the lever in the inside (red arrow) retracts the steering lock but the unit doesn't seem to want to come out even with the lock pulled back. Please help. TIA.
Cvrguy
post Nov 27 2026, 12:41 PM
QUOTE(friethmiller @ Nov 27 2026, 12:35 PM) *
I believe that there may be a very small set screw on the side that releases it (slotted as I recall, maybe 3mm). I have replaced my ignition switch a couple of times. The Chinese ones aren't reliable in the long run. I used a Porsche packaged one last time and it has been good so far. It looked, in every respect, exactly like the cheaper Chinese ones. Fingers crossed.
friethmiller
post Nov 29 2026, 12:39 PM
QUOTE(Cvrguy @ Nov 27 2026, 12:41 PM) *
Thanks @Cvrguy! I still can’t find anything that helps removes the ignition housing. Can anyone provide more detail on removing this?
friethmiller
post Nov 29 2026, 01:32 PM
I figured it out! Just used a punch and made sure the steering lock was disengaged. Just need to restore one good one out of these two cores.
Montreal914
post Nov 29 2026, 01:49 PM
I saved this link a while back for when I would get there.
http://www.performanceforum.com/wesvann/91...ing-column.html
Good luck and post pictures. (IMG:style_emoticons/default/smile.gif)
7 User(s) are reading this topic (5 Guests and 0 Anonymous Users)
2 Members: Mowog4, HugoNL914
- Lo-Fi Version Time is now: 29th November 2026 - 02:29 PM
