My lightweight project update, almost ready for paint |
machina |
Aug 4 2003, 02:34 PM
paul,
I remember a few years ago when your car still had actual doors, that I asked you about stiffening the chassis. Did you ever add chassis stiffening plates or boxed rockers? I know some other guys add extra braces to the swing arm support etc. on a car that is as extreme as yours. looks good, david rosenbloom |
Brad Roberts |
Aug 4 2003, 03:05 PM
Fiberglass targa bar.. it fools 99% of the people who walk up to my tube car. They think its steel.
B |
URY914 |
Aug 4 2003, 03:45 PM
I built the lightest 914 in the history of mankind. Group: Members Posts: 120,147 Joined: 3-February 03 From: Jacksonville, FL Member No.: 222 Region Association: None |
I don't think the paint really adds that much to the weight. Even a gallon of paint would only weight about 10 pounds.
As far as stiffeners are concerned, I intend to add stiffeners in the form of bars to the back end. I'll tie the inside trialing arms ears and the upper shock area to the main roll hoop. I don't plan on adding plates or boxing the rockers. My intent is to stay as light as possible and my engine will be in the 150-175 HP range. If I was running a 300 HP -6 I'd need all the stiffening possible. It is an autox car that doesn't need big ass NASCAR door bars or a full cage. I'm trying to keep the balance between weight/HP/brakes/stiffness somewhat equal. Paul |
redshift |
Aug 4 2003, 03:58 PM
URY914 |
Aug 4 2003, 04:38 PM
Yamaha KZ1200
RICE!! |
Aaron Cox |
Aug 4 2003, 08:56 PM
(IMG:style_emoticons/default/MDB2.gif) and then you got a full on gokart!
Lo-Fi Version | Time is now: 25th April 2024 - 03:55 PM |
