Lash Caps? |
Lash Caps? |
RustyWa |
Aug 4 2003, 01:52 PM
Working Member Group: Members Posts: 610 Joined: 2-January 03 From: Kent, WA Member No.: 72 |
I've just got a couple questions about lash caps on a type 4 engine.
What are they generally used for? Do you have to make any geometry adjustments like you would for the 911 swivel feet adjusters? |
Mueller |
Aug 4 2003, 04:32 PM
Some engines use lash caps as a means of adjusting the valves instead of the threaded adjuster like we use. In a stock Type IV, the use of lash caps are a band-aid, IMHO.
If the valve stems are pitting and mushrooming, the lash caps will prolong the life of the valves. |
Lo-Fi Version | Time is now: 10th May 2024 - 09:44 AM |
