Subie swap guys: 300hp N/A motor!? |
Kostamojen |
Sep 20 2005, 05:39 PM
Newbie Group: Members Posts: 37 Joined: 30-July 05 From: Roseville, CA Member No.: 4,504 |
This just showed up over on the Subie forums... Thought some of the 914 guys might be interesting (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif)
http://zzyzxmotorsports.com/events/300hpna/ Its the first 300hp N/A 4-cylinder subaru engine that ive heard of, definatly the first in the U.S. Sounds absolutely perfect for a 914 swap, since you can still fit the radiator in the engine bay (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif) |
bondo |
Sep 20 2005, 05:48 PM
The dyno sheet at the bottom was printed on 9/14... a sign? (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif)
Mueller |
Sep 20 2005, 05:59 PM
you might still be able to run the radiator in the engine compartment with a turbo engine, it really is all about cooling...a 300hp n/a motor is still going to be putting out a lot of heat so it's not a given that it'll work right off the bat....
I bet that motor cost a bundle......a turbo motor might still be cheaper... |
TonyAKAVW |
Sep 20 2005, 06:53 PM
That's my ride. Group: Members Posts: 2,151 Joined: 17-January 03 From: Redondo Beach, CA Member No.: 166 Region Association: None |
Look at that torque curve!
The high octane gas requirement kinda sucks for daily driver use. -Tony |
Kostamojen |
Sep 21 2005, 07:32 PM
Its not a daily driver engine, In one of the posts they made they clarified it was designed for race applications... But I would think 250hp or could be done and keep it more daily-driverable.
But ya, its probably expensive, somewhere around $7000 we guessed... |
Lo-Fi Version | Time is now: 17th May 2024 - 11:56 PM |
