Dr. Roger |
A bat out of hell. ![]() ![]() ![]() ![]() Group: Members Posts: 3,944 Joined: 31-January 05 From: Hercules, California Member No.: 3,533 Region Association: Northern California ![]() |
Im switching to upgraded switches, wiring, and fuses/fuse box.
The first thing i'm running up against is knowing how many Amps is drawn for the headlamps low/high circuits. I'd like to keep the left and rights, low/high beams seperatly fused and one master switch like the stock configuration. In addition, also seperating out the switched circuits in the main headlight switch. (running lamps, accessories, and ignition) and fusing them seperatly. Estimated Amperage draw for headlights is: running light: ignition: accessories: starter circuit: You guys are always top on my list. (im trying to counter act the negativity of yesterdays BS) (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) Best regards, Roger |
Lo-Fi Version | Time is now: 11th July 2025 - 08:59 AM |
