Bartlett 914 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,218 Joined: 30-August 05 From: South Elgin IL Member No.: 4,707 Region Association: Upper MidWest ![]() |
Hi all
I recently picked up a 74 2.0. This car has not run in 20 years. I pulled the gas tank and fuel pump which was a mess. I changed the oil and I pulled the plugs. The compression is even on all 4 at 70 lbs. I know this is quite low. Is this to be expected? Should I try to get it started before doing another compression test or should I just resign myself that this motor must be rebuilt. I does have 88K on it. Thanks Mark |
MarkV |
Fear the Jack Stands ![]() ![]() ![]() Group: Members Posts: 1,493 Joined: 15-January 03 From: Sunny Tucson, AZ Member No.: 154 Region Association: None ![]() |
All 4 the same, that is good. Are you holding the throttle open when you do the test?
I would drive it, 88k isn't much. |
Bartlett 914 |
Hi Mark
No I wasn't holding the throttle down. I will try that. The battery is also begining to get a little weak. I was never able to get the oil lamp off. Mark |
Crazyhippy |
Insert witty comment here... ![]() ![]() ![]() Group: Members Posts: 1,659 Joined: 28-July 05 From: Home of the Coyotes, AZ Member No.: 4,493 Region Association: None ![]() |
depending on how long it's been sitting, it might need some miles to let the rings re-seat to put up a decent compression #...
Sounds like a combination of a weak battery and a closed throttle caused this one though. Re-check w/ a fresh battery and the throttle WFO BJH |
Bleyseng |
Aircooled Baby! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,036 Joined: 27-December 02 From: Seattle, Washington (for now) Member No.: 24 Region Association: Pacific Northwest ![]() |
wedge the TB open while you turn the motor over lots of rpms. A fresh battery helps.
Try a third test by squirting a tad of oil in each cylinder before testing and see if it goes up. (IMG:http://www.914world.com/bbs2/html/emoticons/monkeydance.gif) |
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 42,257 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California ![]() |
just my humble opinion, but *ANY* motor that has been sitting for 20 years (or 10, or 5 for that matter) should be taken apart before you even try to turn it over. unless it was stored *correctly* in a climate controlled enviroment where moisture in the air isn't a problem ... god knows how the internals look like (think RUST) and you might just kill a bearing or two or add some nice grooves to the cylinders from simply turning it over ... (IMG:http://www.914world.com/bbs2/html/emoticons/cool.gif) Andy |
jd74914 |
Its alive ![]() ![]() ![]() ![]() Group: Members Posts: 4,852 Joined: 16-February 04 From: CT Member No.: 1,659 Region Association: North East States ![]() |
I'd atleast spray some marvel mystery oil down the spark plug holes into the cylinders. OT: Is your car the one in your avatar? Cause if it is its a 75 or 76 |
Bartlett 914 |
Thanks for the input.
I have read several posts about people starting and using motors that had been sitting. I wanted to see if it would run. I have decided to pull the motor. I see too much of a chance to ruin this motor. The motor is in a project 74 car I picked up. My avitar is my regular car and is a 75. I plan to rebuild this 74 motor and install it in the 75. Mark |
jd74914 |
Ok, that makes sense now. You shouldn't need to rebuild the whole thing. Replacing the rings should give you better compression. (I personally would redo everything so you'll have a new and hopefully trouble free engine)
Lo-Fi Version | Time is now: 14th July 2025 - 08:47 PM |
