The 3.2 Conversion Thread, got to git 'er done |
Steve |
Oct 1 2005, 06:02 PM
914 Guru Group: Members Posts: 5,595 Joined: 14-June 03 From: Orange County, CA Member No.: 822 Region Association: Southern California |
You don't have to modify the engine lid. Just move the air flow meter over 3" The 3.2 fuel filter screws onto a fixed metal fuel line in the 911. It was easier for me to just get a fitting from Pegasus and then slip rubber high pressure fuel line over it. I like my combo gauge. You can always get a combo gauge and then put a fuel gauge and voltmeter in the ashtray. It was easy for me to just drill out the dash for the fuel gauge. There are holes already there for extra switches. I drilled out an extra hole and put in a voltmeter. Wow that car is sweet. I have never seen a 914 with a Boxster transmission. I wonder what the cost diference is between that and a 916. Its got to be cheaper, better shifting and less hassle. |
John |
Oct 1 2005, 08:49 PM
Hmmm.... The pics sure show it working out. I guess i'll look at doing that too. (Sure beats flipping the intake around 180) I didn't put the DME under the dash because I kept the STOCK 911 DME wiring harness intact. I used the 911 rear wiring harness, because it was easier to do that when I eliminated the relay board and the rest of the stock 914 harness. I stripped all the unused wiring out of the harness and assimilated the 911 harness into the remaining 914 harness. Later I stripped all the front wiring out of the car (except for the fuel level wires and the fuel pump wires). Now the car only uses 3 fuses fuel pump, DME, and Brake Lights. My street car will still be a street car (but with the big motor). |
Steve |
Oct 1 2005, 09:35 PM
If you look at most of the pictures of 3.2 conversions you will notice that they extended the air flow meter with a pipe and an adapter and moved it over. PMS and GPR sell a kit for this. I brought the air flow meter to Home depot to figure out the size of the pipe to extend it and the adapter required to do it. I also used the stock DME and did not cut or modify the DME harness/cable. There is a round indentation in the firewall behind the passenger seat. I cut out the indentation and made the whole big enough for the rubber grommet of the harness. I then routed the cable behind the seats and used one of the screws to hold the DME brain behind the drivers seat. I'm 5'10" and I never put the seat all the way back anyway. Some people cut the cable and put it behind the passenger seat but I didn't want to go through the hassle. |
ABC914 |
Oct 2 2005, 10:33 AM
Newbie Group: Members Posts: 24 Joined: 24-July 04 From: Princeton, NJ Member No.: 2,391 |
Absolutely correct! I paid someone. I'm not young enough to do this work myself. As it was, it took 18 months at a professional Porsche shop to do it. Time well spent, but still a lot of time. Let's not go into the expenses. (IMG:http://www.914world.com/bbs2/html/emoticons/ohmy.gif) I could have bought a whole Boxster (used) surrounding the transmission for what it should have cost me. Bottom line, they did a great job at a severe discount that made it all worthwhile. (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif) |
kdfoust |
Oct 4 2005, 10:41 PM
Senior Member Group: Members Posts: 694 Joined: 2-January 03 From: Riverside Member No.: 71 Region Association: Southern California |
"It'll never fit."
-Robert Ignoring Robert's input on the engine fit my plan is coming to fruition. (IMG:http://www.914world.com/bbs2/html/emoticons/aktion035.gif) Mwahahahahaha! The engine arrived today. Well, I should say that I went and fetched it today from the freight terminal. I've got a crew lined up for this Saturday to install the beast. We've got three engineers, an HR professional, a logistics expert, a musician, and an IT geek. This doesn't include the random collection of neighbors that'll wander by. None of us have done this before. This will be one hell of a good time. All the PMS stuff for the first phase arrived yesterday. Thats the engine mount (that cool PMS swiveling mount), the clutch/flywheel conversion pieces (KEP), and the engine sheet metal. I gotta get the mount bolted to the firewall in the car and the sheet metal fit up before Saturday morning. Tomorrow the engine mount is going in AND I still need to POR-15 the hell hole while it's easy to get to. The Bentley Carrera manual showed up today as well so I can start ciphering on the fuel lines and electrical hookups. Later, Kevin Attached image(s) |
swood |
Oct 5 2005, 07:51 AM
Senior Member Group: Members Posts: 1,839 Joined: 6-February 03 From: Strong Beach Member No.: 251 Region Association: None |
Make sure you photo document the install for us to get inspired. You got me thinking about the 3.6 |
swood |
Oct 5 2005, 08:37 PM
Do you also get to set up the a/c with that engine? That would be a bonus on top of the hp.
(IMG:http://www.914world.com/bbs2/html/emoticons/burnout.gif) |
redshift |
Oct 5 2005, 08:41 PM
If it won't fit, I think my car is the next size up. (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif) Niceness. M |
bd1308 |
Oct 5 2005, 08:44 PM
turbo, what the hell is that black thing???
Looks mean Awesome! b |
736conver |
Oct 5 2005, 09:11 PM
Advanced Member Group: Members Posts: 2,117 Joined: 25-May 03 From: SE Wisconsin Member No.: 736 Region Association: None |
Its an electric turbo (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif)
bd1308 |
Oct 5 2005, 09:13 PM
Only because I am gullible will I believe that. Looks like a turbo..... i dunno nuphin about dem 911s.... |
736conver |
Oct 5 2005, 09:15 PM
Its just the heater fan. Its the tubing that makes it look exotic.
Oct 5 2005, 09:26 PM
flat black paint on the front shock towers, no hole in the front firewall for the windshield washer hose to the spare tire ... (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif) Andy |
kdfoust |
Oct 5 2005, 11:47 PM
Naw, no AC. That would be trick wouldn't it! I did get the super cool Porsche die cast aluminum mount for the compressor. I will keep it just in case... (IMG:http://www.914world.com/bbs2/html/emoticons/cool.gif)
Tonight I worked on installing the chassis side of the engine mount. The picture is sort of like an artists conception of what it will look like installed. I did pretty much empty the interior of the car (backpad and seats out) and drilled the mounting holes for the engine mount. It turns out that the firewall is a box section down low. There is about 1-1/2" air gap between the engine side and the interior of the firewall down low. I'll wait till the crew arrives on Saturday to actually mount everything since it'll be a three-handed-job. Attached image(s) |
736conver |
Oct 5 2005, 11:52 PM
Are you going to try and git 'er done in one weekend with all your help. That would be cool.
kdfoust |
Oct 5 2005, 11:53 PM
The engine side of the mount doesn't quite fit correctly. 3 out of 4 holes line up perfectly. I need to open up one hole +1/16" so I don't risk boogering the thread in the case. I'm ask Jim Patrick about this tomorrow to see if he's seen this before.
736conver |
Oct 6 2005, 12:00 AM
You know thats funny about that hole, mine was the same way. My mount wasnt a PMS mount though. It was homemade for my 2.2 and fit perfect. But when it was transfer to the 3.2 it didnt fit. I had to enlarge the hole. (IMG:http://www.914world.com/bbs2/html/emoticons/confused24.gif)
kdfoust |
Oct 6 2005, 12:02 AM
Here's a look at the engine sheetmetal. The OE carrera engine sheet metal is the dirty stuff on the inside, the PMS -6 metal is around the outside in the corresponding locations. You can see that there are some holes and stuff that I need to add. Tomorrow evening I want to get the engine sheet metal fit up with all the needed holes. Actually when I first looked at it I though a mistake had been made. I can now see how this will go together.
kdfoust |
Oct 6 2005, 12:14 AM
IT would be cool. One of the crew wants to do burn-outs in the street on Saturday night. If it was finished that quick I'd let him. (IMG:http://www.914world.com/bbs2/html/emoticons/happy11.gif) We will get the mechanical install completed Saturday. It'll take a little longer to get everything else hooked up. If I had all the pieces laid up at hand I think we could do the whole thing in a weekend. We've taken on pretty ambitous "tech sessions" (our word for various projects) and succeded. It might be fun to do the final hookups in a tech session later this month with the goal of everybody taking it for a spin in the evening. (IMG:http://www.914world.com/bbs2/html/emoticons/driving.gif) Later, Kevin |
Steve |
Oct 6 2005, 04:36 PM
Best of luck with your project.
It looks great. Let me know if you need anything. I still have all my hand written notes about the electrical stuff. I can also swing by with my car if you want to take a look at it. Steve |
Lo-Fi Version | Time is now: 23rd May 2024 - 12:16 PM |
