Air_Cooled_Nut |
914 Ronin - 914 owner who lost his 914club.com ![]() ![]() ![]() Group: Members Posts: 1,748 Joined: 19-April 03 From: Beaverton, Oregon Member No.: 584 Region Association: None ![]() |
The AAR is stuck open on my 2.0L. In fact, when I connect it to the power source it pops the fuel pump fuse (25A) (IMG:http://www.914world.com/bbs2/html/emoticons/mad.gif) I put a clamp on the hose so now I have to feather the throttle at stops until the engine is warmed up. Obviously, if I take the clamp off then the engine will idle really fast once op temp is reached.
I found a "spare" unit but it, too, is stuck open. Why can't they stick closed? (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) So, what is there to replace it? I tried the 914 on-line part stores no no avail. AA was a PITA to "flip" thru their on-line catalog (yeah...whatever) and I get bored and gave up looking thru it. The device looks exactly like the unit I had on my previous Type 3 automatic -- which served the same function and was powered by the coil. So I got to thinking, the other units out there, for cars like water-cooled VW engines, use a similar device, just a little more aerodynamic looking (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) Would one of those (less expensive) units work? Can someone point me to a place that does sell AAR's for our cars (not a "I think such-n-such sells them")? What have others done to fix or replace their failing units? Thanks (IMG:http://www.914world.com/bbs2/html/emoticons/beer.gif) |
redshift |
Bless the Hell out of you! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,926 Joined: 29-June 03 Member No.: 869 ![]() |
N L A
Some guy who lives in one of those unnamed North Western states has some, but he'll make you do all kinds of bad things, then pay shipping.. (IMG:http://www.914world.com/bbs2/html/emoticons/unsure.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/pray.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/spank.gif) Trick... don't connect it to power... the engine heat will eventually (few extra minutes) make it close. Take it out, and clean it with some PB Blaster, then remount that puppy, and enjoy. M |
Air_Cooled_Nut |
Yeah, I know engine heat will do it as well. I wonder why they don't use the pure mechanical units like those on the VW manual transmission engines (spring is located on top of the case, near the oil breather, where oil can splash on it)?
Air_Cooled_Nut |
Well, I'll see about busting open the 'replacement' unit that came with the car and fiddling with that. I did squirt PB Blaster in it and washed it around but no luck (IMG:http://www.914world.com/bbs2/html/emoticons/sad.gif) One web site said to pop it in a vice and pry back the body to get to the innards for fixing it. I guess we'll see (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif)
Hammy |
mr. Wonderful ![]() ![]() ![]() Group: Members Posts: 1,827 Joined: 20-October 04 From: Columbia, CA./ Tuolumne Member No.: 2,978 Region Association: Northern California ![]() |
don't have an answer but
what's this AAR... what's it do (IMG:http://www.914world.com/bbs2/html/emoticons/huh.gif) |
914 Idiot ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 15,204 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California ![]() ![]() |
Auxiliary Air Regulator. It lets air bypass the (closed) throttle plate when the engine is cold. That raises the cold idle RPMs somewhat, and more importantly keeps the cold idle RPMs from being "zero".
ACN, it sounds like the heating element in your AAR has shorted to the cannister. Check the resistance from the plug to the housing of the AAR; it should be about 13 ohms. Bet you find more like zero. If that is the case, opening it up is the only way to fix it--you can pull out the coiled "resistance wire" that's in there, and replace it with about 13 ohms worth of 1-watt (or 1.5 watt, if they make those) resistors. They should heat up at pretty close to the same rate as the original wire did. You could also adapt a later car's "cold idle air bypass" mechanism to the 914, if you were so inclined. If the bypass is a simple heated valve like the stock part, then you just have some hoses and wires to hook up. Of course, it may let the wrong amount of air through at various times during the warmup, but that'll just mean the engine will idle a "little funny" for those first few minutes of driving, which is probably no big deal. There's a new 914 owner over on the Yahoo group who replaced the AAR with a manual version (he will be installing a "choke cable" for it Real Soon Now) without even bothering to test his AAR. But I'd still try to fix the original part if you can. --DD |
type47 |
Viermeister ![]() ![]() ![]() ![]() Group: Members Posts: 4,254 Joined: 7-August 03 From: Vienna, VA Member No.: 994 Region Association: MidAtlantic Region ![]() |
sounds like you have a D-jet. maybe you could look into converting an L-jet AAR to D-jet. if i recall, L-jet AAR's are still available.
brp914 |
Unregistered ![]() |
Yep, thats what I did. Works fine, problem is, you need a 2 pin connector (just like fuel injector connector). Back when import car parts stores were around I would get stashes of these plastic connectors and the electrical contacts inside them. Prolly cant do that anymore, but auto atlanta sells them with rediculous mark-up. |
bd1308 |
Sir Post-a-lot ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,020 Joined: 24-January 05 From: Louisville,KY Member No.: 3,501 ![]() |
plastic connectors and wires are available from Beck-Arnley (a god send for me)
DD, you have the part numbers, you gave them to me at one point....(i could use them again myself) 4-pin plastic connector 5-pin plastic connector wiring inserts for connectors pin release tool b |
Air_Cooled_Nut |
Thanks guys, and DD for a way to electrically test it.
No, no choke cables for me! I'll adapt some other unit...not crazy about putting more holes in the firewall or having to fiddle with additional controls. |
redshift |
(IMG:http://www.914world.com/bbs2/html/emoticons/ohmy.gif) AND WASTE A CHANCE TO USE A PIECE OF BROWN WIRE!? ARE YOU INSANE? -fffffufff...- M |
Brando |
BUY MY SPARE KIDNEY!!! ![]() ![]() ![]() ![]() Group: Members Posts: 3,935 Joined: 29-August 04 From: Santa Ana, CA Member No.: 2,648 Region Association: Southern California ![]() |
Find the part number for a 924 AAR, it's a two-plug unit. I don't know if it's the same as L-jet but the connection is the same. They're fairly inexpensive as well. It's a typical Bosch unit.
Worst case scenario... Disconnect the CSV and plug the hoses for the AAR, manually warm-up your car with the gas pedal (a-la-carbs). |
Air_Cooled_Nut |
Took apart the replacement AAR. Ohm reading was 13, measured from the pigtail connector to the AAR housing. This was an electrically good unit. The one in my car reads 0.5ohms, thus most likely the heating element broke and is touching the AAR housing.
Attached thumbnail(s) ![]() |
Air_Cooled_Nut |
Air_Cooled_Nut |
The bimetalic spring is easily removed and doesn't unwind like a traditional spring. Dropped some oil in the AAR lower hose connection as well at on the spring shaft and turned the shaft with some pliers. There was some minor initial resistance then it rotated. Not very smoothly, there are some rough-feeling spots but after working the shaft back-n-forth it moved more easily.
Air_Cooled_Nut |
Adjusting/retaining spring screw. In the setting shown, the spring will open more quickly. If the spring is adjusted to the opposite side of the slot, it will open more slowly.
Air_Cooled_Nut |
For my application I removed the ceramic cup, fiber washer and pigtail. Just a picture to show how it looks. To remove the ceramic cup the two rivets on the bottom of the AAR housing need to be drilled out.
Air_Cooled_Nut |
I removed the ceramic cup and bits then put the top part (the spring and holder) back onto the housing. A couple of tack welds to hold it together then filled the seam with hi-temp silicone sealer (the copper-looking stuff). The housing didn't want to weld back together very well and left a white silky residue so I think the housing is zinc'd or something. It is ferrious (magnetic). I left the holes where the rivets and pigtail are located at the bottom of the housing open. This will allow oiling if it should need it plus let heat in and moisture drain since I'm not sure how good my silicone seal will hold up.
Haven't had a chance to test it as it's raining quite heavily outside and my door/window seals ain't the greatest...plus the hood is still off. Cold engine started right up and idled so I know that cold-starting is working fine. The real test will come once the engine is at operating temp as the AAR should completely close up and keep the idle from hitting the 2000+rpm like she previously did (IMG:http://www.914world.com/bbs2/html/emoticons/wacko.gif) I'll report back when I can on how it works. |
jsteele22 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 727 Joined: 24-August 05 From: Colorado Springs, CO Member No.: 4,653 ![]() |
Cool pics ! It would be great ot see a gallery of parts like this one, either dismembered or intact (for "What does the AAR look like?" type posts). BTW, did you do a test of the AAR resistance ? My AAR was killing my engine b/c the wire to it was dry and cracked, and shorted to the engine. Kept blowing the fuse to the ECU. Finally tracked it down when the fuse didn't blow, and I saw an awesome display of sparks shooting out from down there. Currently, I don't have an AAR. We'll see if I bother with it when cooler temps set in... |
Air_Cooled_Nut |
Just came back from a test run -- failure (IMG:http://www.914world.com/bbs2/html/emoticons/sad.gif)
I thought the stock location would soak enough engine heat but my whole engine isn't very hot at all. I drove her for about 15 minutes, and on 45-55mph zones, up into the rpms, so I know she was at operating temp. The engine just idled fast so I had to clamp the hose shut to get the idle back down to stock. Looks like the spring element needs to be in constant heat which I now understand why there's either an electric heating element constantly heating it or, in the case of the manual tranny FI VW engines, the element is in the engine case constantly getting splashed with oil. Oh well, nothing ventured nothing gained so back to the drawing board (IMG:http://www.914world.com/bbs2/html/emoticons/smash.gif) |
Lo-Fi Version | Time is now: 16th July 2025 - 03:56 AM |
