Coil-over install pics, Lets see if this works |
ChrisReale |
Aug 7 2003, 10:33 PM
Put car on jackstands and if you desire, remove both rear wheels
ChrisReale |
Undo top mount nut
ChrisReale |
Aug 7 2003, 10:35 PM
Unbolt bottom nut and slide bar out from strut and rear arm. Might be a good idea to support the rear trailing arm so it doesnt fall down onto your heat exchangers
ChrisReale |
Aug 7 2003, 10:37 PM
Remove spring/shock combo and undo the top bolt that holds the spring hat on. If you have stock springs, rent a compressor. If you have 140 or 180# springs, you probably wont need a compressor. Black rubber donut goes on the top of the assembled unit
ChrisReale |
Now, I put the new threaded collar onto the shock
ChrisReale |
Aug 7 2003, 10:39 PM
The threaded collar acts as an adjustable spring perch, with "infinate" height adjustment (IMG:style_emoticons/default/wink.gif) Basically, you can corner balance your car better, and lower it a few more inches. Assemble unit and re-install. The procedure is opposite of removal (IMG:style_emoticons/default/laugh.gif)
See that black donut on the left of the pic? DONT FORGET TO PUT IT ON!!!! Attached image(s) |
ChrisReale |
Aug 7 2003, 10:42 PM
Pretty easy process. On left is a stock weight spring, middle is 180# progressive, and right is 200# Hypercoil
Big difference! One nice thing about this set is the top spring hats have two holes pre-drilled so you can zip-tie the springs to the hats easily Attached image(s) |
Brad Roberts |
Aug 7 2003, 11:08 PM
Grass Hopper has a come along way..
Good job. (IMG:style_emoticons/default/clap56.gif) Oh.. I dont take the wheel off. No need. B |
maf914 |
Aug 8 2003, 07:16 AM
Chris,
Good photos and info. Thanks. Who supplied the hardware? Collars, rings, and springs? I have Koni reds and would like to go this route, with a 120 or 140 spring rate. Mike |
philinjax |
Aug 8 2003, 07:35 AM
Member Group: Members Posts: 54 Joined: 26-March 03 From: Jacksonville, Florida Member No.: 476 |
What's that ball on the bolt head in the third pix. above??? Don't remember ever seeing that before.
philinjax (IMG:style_emoticons/default/blink.gif) |
redshift |
Aug 8 2003, 07:36 AM
QUOTE(philinjax @ Aug 8 2003, 09:35 AM) What's that ball on the bolt head in the third pix. above??? Don't remember ever seeing that before. philinjax (IMG:style_emoticons/default/blink.gif) Right side trailing hitch. Factory towing option. I wonder if he has the teeny lil trailers? M |
seanery |
Aug 8 2003, 07:41 AM
waiting to rebuild whitey! Group: Retired Admin Posts: 15,841 Joined: 7-January 03 From: Indy Member No.: 100 Region Association: None |
looks like a rear bar mount to me.
JmuRiz |
Aug 8 2003, 07:50 AM
914 Guru Group: Members Posts: 5,423 Joined: 30-December 02 From: NoVA Member No.: 50 Region Association: MidAtlantic Region |
Yup, it's the rear sway bar mount...and boy is it a PITA to get back on. At least mine was when I did my adj coilover install. Also, the zip-ties that I used to attach the spring top to the spring hat lasted all of 2 seconds...anyone have a remedy for this...maybe just attach them loosely? Thanks
seanery |
Aug 8 2003, 08:02 AM
what about safety wire?
rhodyguy |
Aug 8 2003, 08:15 AM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,060 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
so chris, are you going to install one of those air cushioned seats that are in kenworths/peterbuilts so you can still drive to ore?
kevin |
Jeroen |
Aug 8 2003, 08:29 AM
Hey Chris,
Good pics and write up! Remind us in a little while to move this thread to the "classics" cheers, Jeroen |
KenH |
Aug 8 2003, 09:18 AM
Senior Member Group: Members Posts: 680 Joined: 16-January 03 From: Gilroy, CA Member No.: 156 |
Who made the Coil Over hardware???
Ken |
brant |
Aug 8 2003, 09:28 AM
914 Wizard Group: Members Posts: 11,613 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
I've had better luck with safety wire over zip ties...
brant |
Brad Roberts |
Aug 8 2003, 10:04 AM
Um guys ???
Your not tying the top AND bottom down are you ??? I have cars running round for 5-6 years with the same zip ties. Yes.. the rear sway bar is a PITA to get back on the mounts. B |
redshift |
Aug 8 2003, 10:06 AM
So you just jack it up, adjust the collars (I imagine those are set screws around the edge?) and there you go..
Those are the C2 parts you were asking about? I like that. Where do you start when adjusting those? M PS: WD-40 would remove that nasty crap on your dolly, AND SKIN! |
Lo-Fi Version | Time is now: 25th April 2024 - 04:11 PM |
