> wiring supplies, Wanna make a new lighting harness
Sparky
post Oct 4 2005, 08:56 PM
Mahna Mahna!
So where do I get the wire from? I'd like to use the same colors as in the factory harness example: the right side marker and right tailights are a shared gray wire w/red tracer on a '72.
I checked the McMasters-Carr site but found doodley poop.
Suggestions?
My best,
Mike D.
Aaron Cox
post Oct 4 2005, 10:17 PM
Professional Lawn Dart
see about digikey.com
914GT
Mike,
Waytekwire is one possible source for automotive primary wire. This PDF of their catalog page shows they can provide wire with various striping. I don't know what the cost would run though. Would be nice to have bulk rolls of some of the wire colors used in the 914.
lapuwali
post Oct 4 2005, 10:31 PM
Not another one!
Waytek requires a sizable minimum order to do striping, much more than required to do several cars. They don't stock the stuff, it's custom. The only place I know of that stocks bulk tracer wire, esp. with proper automotive insulation, is a mom and pop called British Wiring. They're not cheap, but they're cheaper than Waytek for the amount of wire required to repair one harness. They also have the correct spade terminals to replace the factory parts, and they sell good crimpers. They'll sell you just a couple of meters of wire in any color you require, including with a tracer.
Digikey doesn't sell tracer wire, either, and doesn't even offer as many colors as Waytek does. They also don't sell much automotive grade wire. Most of their stuff is solid-core, fine for hooking up stationary electronics, but terrible for wiring a car. The insulation on their stranded wire isn't rated for particularly high temps, nor is it oil or fuel resistant.
Sparky
post Oct 4 2005, 11:45 PM
Mahna Mahna!
Thanks for the replies, I'll check out the mom and pop and report back...
>M<
Dr. Roger
post Oct 4 2005, 11:51 PM
A bat out of hell.
I've spent the last three weeks looking for the "right" wire to replace much of my harness and had no luck.
I'm going to the easier to find aftermarket stuff.
If you end up finding a source for the correct wire you should post your source and cost. There are many people here who would benifit from that info.
Best of luck,
Roger
JeffBowlsby
post Oct 5 2005, 12:18 AM
Waytek is the closest you will find. Its not exactly accurate in every respect, but you will not find anything better.
michelko
post Oct 5 2005, 05:40 AM
not much helpfull for you us guy´s but this little german shop has the stuff you need.
www.kabel-schmidt.de
Ordered several times, nice stuff (wiring). And if you wish you can order the complete Wiring
(IMG:http://www.914world.com/bbs2/html/emoticons/smilie_flagge6.gif)
michelko
post Oct 5 2005, 05:42 AM
direkt link to two colour wires
http://www.kabel-schmidt.de/shop/shop.php?...476b92d557f1405
Sparky
post Oct 5 2005, 06:53 AM
Mahna Mahna!
Hey Bowlsby how come you dont offer an updated lighting wiring harness yet?
Mike D.
JeffBowlsby
post Oct 5 2005, 08:24 AM
Say What? I stick to the stock harnesses...if you want something custom, you will need to do it yourself...Right now, I don't have the time to do custom stuff is the bottom line.
There is no separate 'lighting' harness that I know of. If you mean the headlight/foglight circuits, they are in the main harness.
lapuwali
post Oct 5 2005, 08:27 AM
Not another one!
QUOTE (bowlsby @ Oct 4 2005, 10:18 PM)
I've used the British Wiring place, and their wire is high quality. The only reason to use Waytek over BW is the cost of buying enough wire to make a complete harness is quite a bit higher from BW. If all you're making are some small repairs, however, BW is the place, as they have a very small minimum.
eric914
post Oct 5 2005, 10:14 AM
I know it is a pain but you could strip a wire harness from a parts car. If your only goal is to get the wire you can cut the connectors off the ends to make pulling it easier. I have the harnesses from two part cars and they are a good source for pieces.
Eric
lapuwali
post Oct 5 2005, 11:16 AM
Not another one!
QUOTE (eric914 @ Oct 5 2005, 08:14 AM)
Eric
The only real problem with using old harnesses is that insulation DOES age, and that's the primary reason to replace wires. I'm reusing some of the OEM wire in my new harness, particularly the large gauge red wires, mostly to avoid paying out serious money for 250ft of 10g red wire, when I only need about 10ft of it to do the car. If you follow this route, inspect the wire carefully. Bend it in places and look for cracking, and feel the insulation to see if it's brittle or still pliable. Wire that's actually in the engine bay, or near the exhaust, is particularly prone to suffering long-term damage. Oil-soaked wire is also likely to be unusable.
Newer insulation is also better than what was used when the cars were first built. A replacement harness with high quality wire will very probably outlive the rest of the car.
Waytek also sells good quality polyolefin wire covering, and it's an excellent idea to use as much of this as you can afford to protect the long runs of the harness, and particularly in any high oil or heat areas.
ss6
post Oct 5 2005, 11:37 AM
fun city...
Note that factory automotive wire conforms to a higher standard (currently SAE J-1128, IIRC) than most "consumer grade" wire which is usually some flavor of PVC. For your trouble you get better temperature / abrasion / chemical tolerance. I believe most of the Waytek stuff is J-1128, which is at least partially why it is pricey.
TonyAKAVW
post Oct 5 2005, 12:04 PM
That's my ride.
If you don't mind the extra hassle of using a single or amybe just a few colors, you can often times find big spools of PTFE insulated silver plated stranded mil-spec wire on ebay.
Its typically used in aircraft and aerospace applications but could easily be used for cars too. New its extremely expensive, but it shows up on ebay peridically.
like this
or this
Still probably important to jacket the teflon wire with sleeving...
-Tony
- Lo-Fi Version Time is now: 11th July 2025 - 04:15 AM
