Trans Gear oil, What's the best |
Jaiden |
Oct 7 2005, 06:07 AM
Member Group: Members Posts: 346 Joined: 13-January 05 From: Stroudsburg PA Member No.: 3,443 |
So in my other thread I'm trying to tighten up my tailshifter slop and have drained the tranny to check the roll pin on the shift shaft.
I'm gonna have to fill it back up but want to know what's best to use in the tranny. I would like to also know if any addatives are recommented to help out with seals/ syncros/ you know friction modifier that kind of thing. Thanks in Advance! |
Jaiden |
Oct 7 2005, 01:26 PM
Of course I bought 3 quarts (IMG:http://www.914world.com/bbs2/html/emoticons/clap.gif)
914fan |
Oct 7 2005, 03:39 PM
Member Group: Members Posts: 118 Joined: 17-January 05 From: Fountain Valley CA Member No.: 3,460 |
When my trans was rebuilt by Carters in bigbear Ca I was told to run GL5. The tranny siezed and I was promptly told that I should have run GL4. I was told that GL5 is for limited slip and I do not have that. My trans was re-rebuilt and has run GL4 for 30K or so. What am I missing.
slivel |
Oct 7 2005, 05:41 PM
Old car....... older driver Group: Members Posts: 509 Joined: 10-July 04 From: San Diego Member No.: 2,332 Region Association: Southern California |
No, GL-5 does not designate limited slip use. Many high quality gear oil manufacturers make two versions of GL-5 (and GL-4 for that matter), one for non limited slip and one for limited slip. The difference is that one has friction modifiers added. See Capn Crusty's explanation - GL-5 is a higher pressure rating. That's pressure between gear mating surfaces. GL-5 should give your gearbox greater protection as long as its friction qualities allow proper synchro engagement.
Dead Air |
Oct 7 2005, 05:45 PM
Senior Member Group: Members Posts: 1,268 Joined: 9-May 04 From: Buffalo, NY Member No.: 2,042 |
[QUOTE] I'm wondering... What do you do with old stuff? (IMG:http://www.914world.com/bbs2/html/emoticons/confused24.gif) |
Lo-Fi Version | Time is now: 23rd May 2024 - 12:52 PM |
