Lazy left headlight question |
tbil |
Oct 12 2005, 11:03 AM
Newbie Group: Members Posts: 37 Joined: 16-December 03 Member No.: 1,439 |
Anyone come across this one before? Left headlight comes up about 15 - 30 seconds after switch is pulled. Other light is up immediately.
No mechanical binding and swapping the relays makes no difference. Ground wire and attachment points look good. Motor going south? Thanks for any thoughts..... (IMG:http://www.914world.com/bbs2/html/emoticons/screwy.gif) |
aircooledboy |
Oct 12 2005, 11:46 AM
Sweet Pea's 1st ride in daddy's "vroom -vroom" Group: Members Posts: 1,672 Joined: 4-February 04 From: Rockford, IL Member No.: 1,629 Region Association: Upper MidWest |
huh (IMG:http://www.914world.com/bbs2/html/emoticons/idea.gif)
When it comes up late, is it while you are moving? In other words, if the car is sitting in your garage and you pull the switch, does it still come up late? I can't imagine anything that could cause what you have described other than a bad connection/broken wire. On further review, the play stands as called. . . . .I mean, if it only happens when you are moving, it could be the motor getting jarred by a bump. In my autoglass days, we could usually coax a bad door window motor back to life temporarily with a couple sharp, light whacks with a BFH. This post has been edited by aircooledboy: Oct 12 2005, 11:51 AM |
tbil |
Oct 12 2005, 12:38 PM
Good thought. Guess I need to go back through the wires and will try wacking the motor a few times. The delay is the same though, doesn't matter if the car is moving or if the engine is running or not.
lapuwali |
Oct 12 2005, 12:42 PM
Does the left motor move more slowly than the right motor, or does it just wait a bit, then pop up?
If it moves more slowly, I'd suspect you have a bad ground connection to the motor somewhere, and thus low voltage across the motor. If it moves at the same speed, just delayed, I'm baffled. |
Brotherbob |
Oct 12 2005, 01:19 PM
Lazy Hack Group: Members Posts: 152 Joined: 6-September 05 From: Granbury TX Member No.: 4,756 |
His goes up slowly and mine goes down slowly!!headlight that is (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif)
startsw/p |
Oct 12 2005, 01:24 PM
born with a wrench in one hand and a beer in the other... Group: Members Posts: 43 Joined: 25-February 05 From: Great White North Member No.: 3,656 |
Check for voltage drop between motor connections and battery and ground, to do this you need to spin start the motor by hand until the park position picks up and runs the motor around.... or you need a helper to toggle the switch, while you get readings. If that's not the case, try running the motor over and over and see if it clears up, possibly just bad brush contact. If that still doesn't get it, assuming you've switched the relays side to side, and tried pulling the headlight switch in and out like 20 times to clean the contacts, try a used headlight switch. Good luck. (IMG:http://www.914world.com/bbs2/html/emoticons/beerchug.gif)
grasshopper |
Oct 12 2005, 04:53 PM
Advanced Member Group: Members Posts: 2,613 Joined: 10-December 04 From: Valdosta, GA Member No.: 3,258 Region Association: None |
mine does that too.....wierd. Now the right headlight wont even go down.... stuck in that position (IMG:http://www.914world.com/bbs2/html/emoticons/wacko.gif)
Oct 12 2005, 05:32 PM
Resident German Group: Admin Posts: 41,681 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
check the arm that goes from the motor to the headlight ... disconnect the arms on both motors and see if the motors run in sync. (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif) Andy EDIT: oops, typo! meant ARM. the ARM that goes form the motor to the light ... (IMG:http://www.914world.com/bbs2/html/emoticons/wacko.gif) |
tbil |
Oct 13 2005, 10:36 AM
Thanks everyone, really appreciate the ideas. Had jumped to the conclusion that it must be the motor or wiring. Think it's actually the contacts in the switch now. Roughly 15 push and pull cycles of the switch and it's working much better. Will yank it this weekend and clean the contacts. Almost never drive the car at night, haven't used the switch much.
Thanks again. |
Lo-Fi Version | Time is now: 10th June 2024 - 11:50 PM |
