PP & Haynes wire diagrams |
VaccaRabite |
Oct 14 2005, 08:06 AM
En Garde! Group: Admin Posts: 13,432 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
I have wires in my car that are stripped, burned, and otherwise damaged. I have some others that I just found laying loose under the carpet, or dissconnected in the engine bay. The PO did let me know that the car had electical problems, so I was expecting them.
I am trying to decipher the Haynes wire guide. I have not gotten to pulling wire yet, but the wire guides may as well be greek. At the moment I am just trying to undersatnd them. The wire diagram on Pelican Parts is better, as it is in color - its a lot easier to read. Anyhow, my car was sold as a 1976. It was made in September of 1975. All the wire diagrams only go to 1973 (1974 for current flow diagrams - are the the same things?). Did the wireing not change from 74 on? I was hoping not to have to, but the further I delve into this, I know I am going to have to pull the entire harness, fish out and replace bad wires, and clean connections. I read the thread in classics about wire harnesses, it was helpfull. Also, anyone in the York - Baltimore area that wants to help a noobie teener pull the harness out? Electrical systems have always frusterated me. Only had the car for 2 weeks now. Learining more and more everyday - I want it done, but I want to do it right... So, going slow, asking questions, learing and doing. Zach |
ClayPerrine |
Oct 14 2005, 08:26 AM
Life's been good to me so far..... Group: Admin Posts: 15,430 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
The 74 diagram on Pelican's site should be real close for the 76.
It's a current flow diagram. Think of it as a "waterfall" diagram. Positive is at the top. Ground is at the bottom. The "water" flows downhill. As for the electrical problems, you might think about getting a replacement harness from one of the guys on the board. Surely someone here has a 75 or 76 harness out of a junker that is better than the one you have. Keep posting... we will help as much as possible. |
SLITS |
Oct 14 2005, 08:38 AM
(IMG:http://www.914world.com/bbs2/html/emoticons/agree.gif) Cut and splice the areas needed....nope don't have one...have a '70, '71 & '73
If you can find someone with a set of Factory Manuals, the diagrams were printed in color (and can be copied (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) ) |
914GT |
Oct 14 2005, 09:03 AM
Senior Member Group: Members Posts: 1,100 Joined: 11-October 04 From: Tucson Member No.: 2,923 Region Association: Southwest Region |
You may find this useful. There are links to some labeled circuit diagrams there I posted a couple years ago.
ClayPerrine |
Oct 14 2005, 09:32 AM
Here's a wiring harness for sale on E-Bay
VaccaRabite |
Oct 14 2005, 09:44 AM
Do you still have the PDF files that were created from your diagram? The link to the PDF files the the other guy made had long since dissapeared. Zach |
Oct 14 2005, 09:52 AM
The Haynes book has a diagram for 75-76 cars. It's not in color, but between that and the color one on the Bird, you should be able to get the idea.
The "current flow" diagrams are the only ones available for the 74+ 914s. They are not intended to show the physical layout of the electrical system--they are intended to show the electrical connections specifically. The exact position of all of the parts in the car is (at least for those diagrams) completely irrelevant. The earlier comment about "waterfall" is a good one. The diagram are layed out so that the top of the diagram is where the power comes from. The bottom is ground, and is where all of the power goes to eventually. --DD |
914GT |
Oct 14 2005, 10:03 AM
I found one of the PDF files for the engine and uploaded it here. I haven't yet found the stitched PDF diagram for the body, I may have to do that one again. |
ClayPerrine |
Oct 14 2005, 10:05 AM
Gee.. I feel honored... DD is complementing me on one of my posts! (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif) |
Oct 14 2005, 11:37 AM
Resident German Group: Admin Posts: 41,611 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
if it's too hacked, your best bet is to get a replacement main harness from a donor car. there's a thread in the "classics" forum on how to do this. i got my replacement harness from EASY in emeryville for $150 ... (IMG:http://www.914world.com/bbs2/html/emoticons/cool.gif) Andy |
Lo-Fi Version | Time is now: 2nd May 2024 - 09:56 PM |
