I can BARELY get into 1st., spot weld? |
meares |
Oct 21 2005, 12:40 PM
Member Group: Members Posts: 403 Joined: 23-March 05 From: Atlanta Member No.: 3,800 |
my shifter has just taken a sh#t! (IMG:http://www.914world.com/bbs2/html/emoticons/mad.gif) i can barely get into 1st or rev... i'll try to slam it in (which is the only way) 1st gear and it goes into 3rd....i'll immediately try it again and it'll go right into 1st????? (IMG:http://www.914world.com/bbs2/html/emoticons/headbang.gif) the shifter is VERY vague....i can go into 2 and 4 from the same (neutral, in the middle)spot with just a little (and i mean VERY little) movement to the left for 2nd same thing for 3rd and 5th......it's a side shifter and ALL bushings are new....got them from PP....any ideas??? THANKS (IMG:http://www.914world.com/bbs2/html/emoticons/beerchug.gif)
JmuRiz |
Oct 21 2005, 12:42 PM
914 Guru Group: Members Posts: 5,426 Joined: 30-December 02 From: NoVA Member No.: 50 Region Association: MidAtlantic Region |
Typically when my car won't go easily into 1st or Rev I adjust the clutch cable to spec to make sure my clutch is fully released when it's pressed. Check that first.
meares |
Oct 21 2005, 12:44 PM
but it is ALL gears...almost like a shifter adjustment....it will go INTO the 2-5 fine, it's more of a shifter position prob. (IMG:http://www.914world.com/bbs2/html/emoticons/huh.gif)
Aaron Cox |
Oct 21 2005, 12:46 PM
cone screw backed out? check them. adjust clutch. then.. go to your haynes manual, and read about the adjustment you can do at the shifter base, by rotating the rod in the tunnel |
meares |
Oct 21 2005, 12:54 PM
where is the cone screw and is the adj. a pain to do? THANK YOU (IMG:http://www.914world.com/bbs2/html/emoticons/beerchug.gif)
SLITS |
Oct 21 2005, 01:36 PM
Uh Oh....if you replaced your bushings, you would have had to remove two of them |
Andyrew |
Oct 21 2005, 01:40 PM
Check your firewall bushing.
Betcha thats popped out. |
SGB |
Oct 21 2005, 01:43 PM
the "cone screws" are just conical set screws- one back at tran and one at firewall. You have pulverized the bushing at the firewall twixt the shift rod fron and back pieces. It is a cheap piece, but a POS to replace. Gotta take out the shift rod and seperate the pressed in u-jointy thing to put a new bushing there. Use a big vice. PP has a good tech article on it. The biggest challenge is getting the flexy rubber covering back onto the firewall.
Cano |
Oct 21 2005, 02:10 PM
Member Group: Members Posts: 110 Joined: 29-September 04 From: Goshen, KY Member No.: 2,854 Region Association: None |
(IMG:http://www.914world.com/bbs2/html/emoticons/agree.gif)
I had those same symptoms a few weeks ago. Previously I had replaced all shift bushings except the pair where the shift rods connect at the engine bay firewall. Discovered that the two bushing I did not replace basically fell apart. Replaced them and every gear is easy to locate |
lapuwali |
Oct 21 2005, 02:36 PM
Interestingly, I found that with a new cup bushing at the gearbox, a new bushing at the console, new u-joint bushings, and new cone screws, that the firewall bushing does almost nothing to help reduce slop. My firewall bushing popped out (insufficient force installing it), and is now dangling loose on the shift rod, yet the shifter feel barely changed. I can still get all gates nicely, and have no trouble getting it into any gear. Drove the car about 50 miles before I even noticed the bushing wasn't seated.
The bushings kit from PP includes new cone screws, so unless you bought the bushings piecemeal, you should have a set. They back out easily if you reuse them and don't use Loctite on them. New ones have a one-use nylon insert to prevent them from backing out. |
bd1308 |
Oct 21 2005, 02:43 PM
hey....
it's the cone screw..... mine did it like three weeks ago..... 4mm allen key + 10 seconds = (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif) happy camper. enjoy |
Red-Beard |
Oct 22 2005, 06:19 AM
"Ya canna change the laws of Physics" Group: Benefactors Posts: 1,124 Joined: 11-February 03 From: Houston, TX Member No.: 288 Region Association: None |
After you are done "screwing" around, also get the springs and bushings for the shifter. $45 and make a world of difference. Then adjust everything.
Cap'n Krusty |
Oct 22 2005, 07:50 AM
The springs? Why? They don't wear out. The plate does, and the cup does, even the shifter does, but never the springs. Waste of money. The Cap'n
lylegd |
Oct 22 2005, 09:03 AM
Newbie Group: Members Posts: 49 Joined: 19-August 04 From: Fort Collins, CO Member No.: 2,574 |
My vote would be that one of your cone screws has come loose. There are two of them. Usually it is the one in the universal joint that works loose. If that is not the cause, remove the long shaft that goes to the tranny and try shifting the tranny by moving the stub shaft on the side of tranny. How does it work, is the sloppy feeling still there? If so, check the two roll pins used at both ends of the stubby shaft. The pins can totally shear off but they can also crack but still stay in place leaving you with a shifter that still works but is inconsistent in its shifting pattern. It is also possible for the holes that goes through the stub shaft and the two shift levers to become worn out. The roll pin on the inside of the tranny cracked on my car and it was difficult to find until I had removed the shifter console from the side of the tranny. Then the shaft play could be felt AND SEEN.
meares |
Oct 24 2005, 07:14 AM
it was the cone screw on the shift rod next to the transaxle took about three mins to fix!!!!! THANK YOU ALL!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!1 (IMG:http://www.914world.com/bbs2/html/emoticons/beerchug.gif) i'm starting to do little things like this, that is saving me at least $200 each time.....THANK YOU for the input
Lo-Fi Version | Time is now: 16th May 2024 - 08:35 AM |
