rear window defogger people!!!!!, need some info!!! |
grasshopper |
Oct 24 2005, 03:06 PM
Advanced Member Group: Members Posts: 2,613 Joined: 10-December 04 From: Valdosta, GA Member No.: 3,258 Region Association: None |
are these wire the ones that go to the rear window defogger switch???? thanks
ArtechnikA |
Oct 24 2005, 03:10 PM
you need to hold them closer to your screen... |
grasshopper |
Oct 24 2005, 03:13 PM
whoops (IMG:http://www.914world.com/bbs2/html/emoticons/wacko.gif) sorry.....heres the pic
ClayPerrine |
Oct 24 2005, 03:19 PM
Yes.
there are 3 wires there. One goes to the light in the switch, the other are the power in and switched power out. the other 2 wires in the picture are the power (red with white tracer) and ground for the harness. The other end plugs into the relay board in the engine compartment. There should be two more wires that feed the heater element too. |
Aaron Cox |
barry.
yes. the red yellow go to the switch...and The plug is the only trick piece. Green wire ( from relay- 87) goes to window, yellow/red ( 85) should go to dash switch. |
Lo-Fi Version | Time is now: 15th May 2024 - 07:14 AM |
