Why 912 gears in tranny? |
HeloMech |
Oct 26 2005, 12:58 PM
Go Ahead, Get Pistoph! Group: Members Posts: 691 Joined: 31-August 05 From: Roy, WA Member No.: 4,718 Region Association: Southern California |
So I was going over what has been done to the 74 1.8 914 I'm picking up. There was mention of having put 912 gears in the tranny. What's the reason for this? pros? cons?
Aaron Cox |
Oct 26 2005, 01:02 PM
5 speed or 4? A F M S X iirc is a 912 5 speed. very short 5th.... and make good gears for a track box. if a 4 spd... A H Q X... let me know if you are unloading em, weve got some 914 gears (all but a 5th) you can have. |
Oct 26 2005, 02:27 PM
914 Idiot Group: Members Posts: 14,991 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California |
A similar question came up on the Bird's Tech Support system recently. My reply is below:
There was also a five-speed gearbox used on some 912s. A Google search on "porsche 912 gear ratio" should turn up some info. --DD |
lapuwali |
Oct 26 2005, 03:06 PM
A F M S X Most 912s in the US were five-speeds, btw. The five-speed was standard from '65 to '69 in the US, and the four-speed was an option in '67-'68. |
Joe Ricard |
Oct 26 2005, 03:46 PM
Not to hi-jack but I just picked up a free either 66 912 box or 69 911T box.
Haven't looked at the Numbers yet but I am optimistic about the gears inside. (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) |
Aaron Cox |
Oct 26 2005, 03:54 PM
nice. 4 speed boxes pay off well (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif) BTW - 911 box would have a GA mainshaft if its a five speed.... ie - the same 2nd as a 914.6 |
Bleyseng |
Oct 26 2005, 07:27 PM
Aircooled Baby! Group: Members Posts: 13,035 Joined: 27-December 02 From: Seattle, Washington (for now) Member No.: 24 Region Association: Pacific Northwest |
912 Transmission 5-speed 902/1, #163001-165214
923/02 902/02 902/50 (close-ratio 5 speed) Gear ratios, 902/1 and 902/02 5-speeds 11:34, 18:34, 22:29,25:26, 28:24 Grade climbing, standard 5-speed,2490 lb. load 46, 25, 16, 11, 8% 4-speed 902/1(USA), #234001-238942 902/01 Gear ratios, 902/01 4-speed 11:34, 19:32, 24:27, 28:24 Grade climbing, standard 4-speed,2490 lb. load 46, 21, 12, 8% N/A Axle ratio 7:31:1 7.31:1 Final drive ratio 4.428:1 4.43:1 Oil Capacity 2.65 quarts N/A Taken from the 912 Registry Specs. I have taken the 3rd gear "M" (22:29) and 4th gear "S"(25:26) and installed them in my tranny leaving the "ZD" 5th for freeway driving. Should make a good close ratio 914 box for AX and track with the 50 series tires I run. |
Lo-Fi Version | Time is now: 7th June 2024 - 01:28 PM |
