> horizontal bracing, when is it needed?
Trekkor
post Oct 28 2005, 08:06 PM
I do things...
I've seen the pics of tube steel welded between the front and rear shock towers and diagonally in the rear trunk.
Why and when should I do this?
Thanks,
KT
URY914
post Oct 28 2005, 08:14 PM
You mean....
ArtechnikA
post Oct 28 2005, 08:15 PM
rich herzog
between the shock towers: only when your car is too heavy for class rules and you need ballast. or you are running a 100-ltr GT gas tank.
triangulating back to the transmission mount area *might* be a good idea.
URY914
post Oct 28 2005, 08:23 PM
Any flex in the car is force that is not being transmitted to the ground.
You need to stiffen the car to allow the suspension to react to the loads being placed on it by the track.
Jeroen
post Oct 28 2005, 08:31 PM
Region Association: Europe
unless you cut out the firewall(s) you don't need braces between the shock towers
J P Stein
post Oct 28 2005, 08:47 PM
Irrelevant old fart
Right after you put in a roll cage.
The front and back ends of a stock 914 work independently of one another in pitch & roll....prolly yaw too (IMG:http://www.914world.com/bbs2/html/emoticons/laugh.gif)
Bleyseng
post Oct 29 2005, 08:55 AM
Aircooled Baby!
I would install Engman's inner long kit first to strengthen the chassis and reduce body flex. Then I would worry about the other problems .....
As Jereon said, ya don't need it as it comes that way stock!
J P Stein
post Oct 29 2005, 09:05 AM
Irrelevant old fart
QUOTE (Bleyseng @ Oct 29 2005, 06:55 AM)
Oh good, now Trekor comes back with BTDT.
Pick your chassis strengthing with care.
brant
post Oct 29 2005, 09:12 AM
more strength is better, but like all things in life you can go over board.
it comes down to a rules/class versus weight issue.
1st, you'll find that only highly modified classes allow you to tie into suspension points, and you had better be wanting to play in those classes before you do it.
2nd, you really don't need it unless you cut out the factory metal. ie: if you cut out the entire rear trunk floor pan and firewall between the shock towers then you need bars to replace the strength you've taken out.
3rd, weight....... the way I interpret JP's comments about picking with care are exactly the way I chose what to brace and what not to brace. Bars can get heavy. I wanted my car to be light. I added as few braces as possible to get the maximum cost=benefit from the weight penaly.
thats my story and I'm sticking to it.
plus I'm happy with my car weight when I got done.
brant
Tobra
post Oct 29 2005, 09:17 AM
QUOTE (URY914 @ Oct 28 2005, 06:14 PM)
You mean....
You crack me up, perhaps a bit much for a street car though. How much does it weigh with the body on and you sitting in it? (Nice tire, BTW)
- Lo-Fi Version Time is now: 10th November 2025 - 08:01 PM
