| djm914-6 |
Nov 8 2005, 04:33 PM
Happiness is: Getting on the road ![]() ![]() ![]() Group: Members Posts: 1,864 Joined: 6-February 03 From: Burlington MA Member No.: 248 Region Association: None |
It's been a long time comming I suppose. The lever that the pedal pushes on has been tilting to the inboard until the throttle rod rests againts the floor board. Sometimes I'd attempt to bend it back, but most of the time I'd just del with the squeeking.
Well, there's no more squeek because the throttle lever of the pedal assemble broke off. I got the car home by bending he manual throttle lever just enough to catch the throttle cable end. I drove it by pulling back on the lever. Now, I need some ideas. I know that the six lever isn't so common. What's the changes of having this one welded up and reattached to the pin that goes into the pedal assembly? |
djm914-6 Broke the throttle on the six Nov 8 2005, 04:33 PM
ClayPerrine Contact Rich Johnson. He had 5 factory throttle be... Nov 8 2005, 04:37 PM
r_towle post a pic...never seen one...if it can be welded,... Nov 8 2005, 07:32 PM
jkeyzer Are the pedal assemblies for the sixes really diff... Nov 8 2005, 07:40 PM
Aaron Cox the pivot plate that the gas pedal connects to is ... Nov 8 2005, 07:45 PM
djm914-6 Hey Rich, What's the chances that a weld would... Nov 8 2005, 08:05 PM
Eric_Shea The crank isn't different except for the handt... Nov 8 2005, 08:08 PM
r_towle <... Nov 8 2005, 08:12 PM
lapuwali ... Nov 8 2005, 08:35 PM
r_towle brazing is also much weaker than welding.
Rich Nov 8 2005, 08:43 PM
fiid Much is a deceptive word. It's possible to ge... Nov 8 2005, 08:58 PM
Eric_Shea Fixed... http://www.914world.com/... Nov 8 2005, 09:00 PM
lapuwali Nov 8 2005, 09:14 PM
lapuwali ... Nov 8 2005, 09:15 PM
Eric_Shea ![]() ![]() |
Lo-Fi Version | Time is now: 3rd March 2026 - 02:46 AM |
