Better late than never, SDS install pics |
Ray Warren |
Nov 14 2005, 06:51 PM
Member Group: Benefactors Posts: 415 Joined: 1-October 03 From: Canada Member No.: 1,214 Region Association: None |
Air intake temp sensor.
Ray Warren |
Nov 14 2005, 06:52 PM
Fast idle solenoid.
Ray Warren |
Nov 14 2005, 06:53 PM
TPS
Ray Warren |
Nov 14 2005, 06:57 PM
Injector resistors
Ray Warren |
Nov 14 2005, 06:58 PM
Map sensor
Ray Warren |
Nov 14 2005, 06:59 PM
Cold start injector block off plate.
Ray Warren |
Nov 14 2005, 07:01 PM
Mixture meter
Ray Warren |
Nov 14 2005, 07:02 PM
Rich / Lean adjustment knob
Ray Warren |
Nov 14 2005, 07:03 PM
Programer
Ray Warren |
Nov 14 2005, 07:05 PM
Backpad removed and carpeted
Ray Warren |
Nov 14 2005, 07:07 PM
ECM , fuse block and relays
Ray Warren |
Nov 14 2005, 07:17 PM
I have been driving the car with the SDS all summer
and couldn't be happier. I have not had the car on a dyno to be expertly tuned. I tuned it myself with the narrow band o2 sensor and the mixture metre and by sound and feel. It starts and runs perfect every time. I'm sure that if I got it tuned professionally it would be even better. It's a nice simple system. I would recommend it to anyone. |
lapuwali |
Nov 14 2005, 07:20 PM
Do you have any CHT or EGT data on your setup? Typically, these engines tend to run pretty hot when tuned to run at stoich.
Kerrys914 |
Nov 14 2005, 07:30 PM
(IMG:http://www.914world.com/bbs2/html/emoticons/smilie_pokal.gif) VERY nice. Looks very well thought out and installed...The mark of a pro (IMG:http://www.914world.com/bbs2/html/emoticons/beerchug.gif)
Ray Warren |
Nov 14 2005, 07:31 PM
Unfortunately there is no extensive data logging with the SDS. SDS data logging I do have a cylinder temp gauge and it usually runs about 275 to 300. My oil temp gauge is a factory gauge and it usually runs around the "T". |
jsteele22 |
Nov 14 2005, 07:37 PM
Senior Member Group: Members Posts: 727 Joined: 24-August 05 From: Colorado Springs, CO Member No.: 4,653 |
Nice job, Ray. Looks like a super sharp car you've got there. I've got an SDS system lying around that I plan to put in along w/ a Suby 2.5L engine. I'm glad to hear that your experience was so straightforward and positive. I'll be sure and keep you in mind when I (eventually) get around to messing with it.
p.s. Any shots fo your Hall sensor/magnet install ? Probably impossible to see it now. |
Ray Warren |
Nov 14 2005, 07:41 PM
It's a fuel only system (EM4D) I will eventually get a Jake Raby Mallory. I wanted to keep it simple. There is some pictures of Mark Henry's SDS install with ignition on the forum. Do a search on SDS and you will find it. |
lapuwali |
Nov 14 2005, 07:52 PM
I assume you're running off a thermocouple under the spark plug for the CHT? If so, then you're in great shape, and it looks like the usual rule of thumb about running hot near stoich may not be true. |
Ray Warren |
Nov 14 2005, 08:06 PM
Yes I do have the spark plug type sender but I do not know if I am running at stoich. I would suspect it would be close to stoich. Using the narow band o2 sensor and mixture metre is not accurate. I would like to get it tuned with a wide band metre. (maybe next year) |
Ray Warren |
Nov 14 2005, 08:12 PM
CORRECTION
I just went out to the garage and looked at my temp gauge. It usually runs around 300 to 325. |
Lo-Fi Version | Time is now: 18th May 2024 - 08:06 PM |
