Better late than never, SDS install pics |
lapuwali |
Nov 14 2005, 09:05 PM
Still, as long as you're under 350, you're fine. A narrowband meter is reasonably accurate at stoich. It's when you try to tune a car away from stoich that things get hairy. If you've tuned it to run in the stoich range on the meter, you're likely within 0.5 point of 14.7:1. SDS sells a wide-band unit now, and then you can tune for 13.5:1 at WOT, and probably pick up a bit of power. |
airsix |
Nov 15 2005, 02:11 PM
I have bees in my epiglotis Group: Members Posts: 2,196 Joined: 7-February 03 From: Kennewick Man (E. WA State) Member No.: 266 |
Ray,
Looks really good. Tell me about the cold-start solenoid. What's it off of, and will the ECU cycle it to hold a programmed idle rpm? -Ben M. |
Ray Warren |
Nov 15 2005, 06:00 PM
Member Group: Benefactors Posts: 415 Joined: 1-October 03 From: Canada Member No.: 1,214 Region Association: None |
It's actually a fuel tank selector solenoid. I bought it separate from the kit but it is exactly the same one that is an option from SDS. Yes it is controled by the ECM and can be set to any temp that you want. (It is ON or OFF only, it is not a motor). Works perfectly. For engines with stock FI there many types of solenoids like this that can be used if your stock AAR is not working. You would have to use a toggle switch with it though. |
Mueller |
Nov 15 2005, 06:02 PM
what a clean install...makes me want to delete all my pictures of my FI install (IMG:http://www.914world.com/bbs2/html/emoticons/unsure.gif)
Ray Warren |
Nov 15 2005, 06:20 PM
I should explain this a little better. You set the temp in the ECM at what point you want the solenoid to close. The high idle rpm is set by reducing or enlarging the ID size of the hose you are using.(thus creating a larger or smaller vacume leak) I used 3/8 ID hose and put a 3/8 OD x 1/4 ID bronze bushing inside the hose and it high idles at 1500/1600 rpm. |
Mark Henry |
Looks good Ray!
Glad things are working out for you, helps having a nice fresh engine (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif) If your narrow band is off like mine it was running rich...hows the gas mileage? Who needs data logging. (IMG:http://www.914world.com/bbs2/html/emoticons/rolleyes.gif) |
Ray Warren |
Nov 15 2005, 06:32 PM
Hello Mark Engine runs great. (one very small oil leak, inner end of one push rod tube I think) Fuel mileage is not as good as it was with the stock FI but it's still pretty good. For what I use the car for it dosn't matter. |
Mark Henry |
Nov 15 2005, 06:45 PM
You need a WB...Your mileage should be better than stock, your power would be better too.
We'll figure out something next spring...maybe a small rental charge plus shipping and you can use my WB...you would only need it for a week. Once it's set up on a WB your NB will be totally useless. |
Ray Warren |
Nov 15 2005, 06:50 PM
Sounds good to me. |
airsix |
Nov 16 2005, 12:18 AM
Thanks for the info, Ray. Really nice work. (IMG:http://www.914world.com/bbs2/html/emoticons/smilie_pokal.gif)
-Ben M. |
toon1 |
Nov 16 2005, 04:41 PM
Senior Member Group: Members Posts: 1,849 Joined: 29-October 05 From: tracy,ca Member No.: 5,022 |
does this system replace the factory brain? do you use stock fuel injectors?
lapuwali |
Nov 16 2005, 05:20 PM
More than just the factory ECU, it also removes the need for the expensive and impossible to repair MPS. You can use the stock injectors, throttle body, plenum, and runners. For SDS, you'd need to replace the air temp and TPS sensors. I'm not sure what you'd do for the CHT. There are several ECUs you can use for this, SDS, Perfect Power, Link, and Megasquirt (plus others, I'm sure). SDS seems to be a nice system with good support, and there are now several 914s running it. |
Mark Henry |
Nov 16 2005, 05:45 PM
This is one of the bonus points about the SDS You use the factory stock sensor (you get a new one N/C) in the stock location. The owner of SDS is an airplane nut and they have many homebuilts running the SDS system. |
jsteele22 |
Nov 17 2005, 11:27 AM
Senior Member Group: Members Posts: 727 Joined: 24-August 05 From: Colorado Springs, CO Member No.: 4,653 |
Mark, I'm curious about this. Are you saying that after a week or so of "dialing in" the car with a WB sensor, that you would just run open loop (no O2 sensor feedback) ? Or is more of a case of it being so much better you'd never go back ? |
Mark Henry |
Nov 17 2005, 11:35 AM
Once set-up with a wide band it will be out of the narrow bands range...it won't give any reading accept maybe a blip on decel.
I've tried closed loop, I didn't like it because it runs too close to stoch. The aircooled has better head temps running in the high 12's. |
Jake Raby |
Nov 17 2005, 11:40 AM
I run closed loop in the 912 with my SDS and it works great. I just set it up to only be active at cruise speeds and stable MP. The engine runs so cool all the time (250F) That I can afford a bit more temp anyway.
I LOVE SDS! |
Mark Henry |
Nov 17 2005, 11:47 AM
Yeh I didn't play with the closed loop a whole lot, running too good open.
What did you do Jake? Put the value at over 3000rpm? Anyways it doesn't matter now as I think my season is done...were getting snow today...as soon as the salt trucks come out it's game over till spring. |
Jake Raby |
Nov 17 2005, 01:56 PM
It comes on at 3250 and goes off at 3600 the MP is at about 10.9-11.6 so the target area that its functional is a very small window where I cruise at between 70-80 MPH in 5th
I had to watch EGT more than head temp when doing this because if they creep up 2 liter heads are bad about exhaust seats pockets drooping and then the valve job is wated |
jsteele22 |
Nov 17 2005, 02:46 PM
Thanks for the info, guys. Always love to learn more about this. So in closed loop mode, does the SDS always pull you back towards stoich, even with the new wideband firmware ? Or can you set it to maintain a different AFR ? The model I have is the previous generation (SDS-EM3, IIRC) that didn't have that option. Although I'm pretty stoked about getting it set up (if I ever get my new engine...), I'm pretty tempted to sell the SDS and go with megasquirt; I'm real into electronics and embedded controllers, so it's right up my alley. |
Lo-Fi Version | Time is now: 2nd June 2024 - 08:31 AM |
