| dmenche914 |
Nov 15 2005, 08:52 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,212 Joined: 27-February 03 From: California Member No.: 366 |
Hi all: I got a pair of front struts equiped with adjustable shocks, the struts are not on the car. i would like to put the adjustable shocks in my car, and figure it would be easiest to swap the adjustable shock, rather than the whole strut assembly (save redoing wheel bearings, my rotos are half used, and I figure I can deal with the bearings later when the rotors need replacing)
Here the problem, we can't figure how to remove the adjustable shock from the spare struts (we haven't gotten to the ones on the car yet, but they will also be removed) How is the shock removed from the strut assembly? There is a large hex nut on top of the shock, a bent over locking washer, a large notched washer under it, folled by a rubber washer then the top of the strut (with body attachment points) We tried putting the strut in a vice, peened over the lock washer, and turning the large nut, but can't break it free. How can the shocks be removed? PS these are early style (ball joint bolted in) struts if that matters. thanks |
dmenche914 front strut shock removal Nov 15 2005, 08:52 PM
Lou W Do you see a cotter pin at the bottom of the strut... Nov 15 2005, 08:54 PM
davep Is it just spinning without loosening? You will pr... Nov 15 2005, 09:19 PM
dmenche914 The top nut will not turn, seems to flex a bit lik... Nov 15 2005, 09:29 PM
Jeroen clamp the big notched washer in your vice
this pre... Nov 16 2005, 08:38 AM
Mike D. Yes, Big Pipe Wrench, and Lefty Loosy... ![]() ![]() |
Lo-Fi Version | Time is now: 14th April 2026 - 02:49 AM |
