Remove front rubber shock stops?, How many if I lower car? |
dmenche914 |
Nov 21 2005, 01:56 AM
Senior Member Group: Members Posts: 1,212 Joined: 27-February 03 From: California Member No.: 366 |
Got Koni adjustables now up front, will be lowwering the car also by adjusting the torsion bars (will be adding 195 50 series tires, already have rear taken care of.
Each front strut has a tripple bubble rubber stop on the top of the shock. I have heard that if the car is lowered a certain amount, that one or two "bubbles" of the rubber stop need be removed, else you hit them all the time when lowered? What's the deal with the rubber stops? should they be cut down for a lowered car, and how much per lowering of the car? (one inch per inch or???) thanks |
Lo-Fi Version | Time is now: 23rd May 2024 - 02:39 PM |
