Wheel fitment question?, "phone dial" on a 5-bolt conversion |
ChicagoChris |
Nov 23 2005, 06:39 PM
It was jack-stand-tastic! Group: Members Posts: 168 Joined: 3-November 05 From: Chicago (burbs), IL Member No.: 5,062 |
I have a '72 that I will have a 5-bolt on shortly. I want to know if any of the "phone dial" type wheels will work under stock fenders?
I know that they made 15" and 16". But what backspace are those wheels? Are they 6 or 7 wide? Thank you, Chris |
Series9 |
Nov 23 2005, 06:44 PM
'86 and earlier will work. The later wheels can be made to work, but you would need spacers.
7x15 is a good size. |
mskala |
Nov 23 2005, 07:03 PM
Phone dials came in a bunch of different choices.
Not all the combinations, but there are 6", 7", and 8", 15" and 16" diameter, and offsets of 23.3, 52.3, or 65mm. When you look at the back of them they will say ET23 or whatever. The 7x15 ET23.3 are the same offset as Fuchs 7x15. A lot of people have banged out their fenders in the back to make these fit. |
Mueller |
Nov 23 2005, 07:31 PM
I ran the 16x7 Phonedials with a 23mm offset on all four corners with 205/50 tires, just had to pull the rear fenders a little bit, think I did by hand...the lip will have to be rolled up, but not a big deal.......
mine came off an '86 944 turbo (4 fronts) the 8's will not fit without major work.... |
McMark |
Nov 23 2005, 09:01 PM
I (IMG:http://www.914world.com/bbs2/html/emoticons/wub.gif) phonedials.
Aaron Cox |
Nov 23 2005, 09:56 PM
there are 3 offsets available if i recall
23 (early) 36 52 |
Lo-Fi Version | Time is now: 7th May 2024 - 12:01 PM |
