Remove dash top, step-by-step |
watsonrx13 |
Dec 14 2005, 07:34 PM
Advanced Member Group: Members Posts: 2,734 Joined: 18-February 03 From: Plant City, FL Member No.: 312 Region Association: South East States |
Well, I'm in the process of dismantling one of my parts car and I've decided to document the steps used to remove the dash top.
I began removing the top dash pad by removing the instrument cluster. If you haven't removed the steering wheel and knee pad, do that now. Next, remove the 4 screws that hold the cluster to the dash. Now, just pull the cluster forward, without removing the electrical connections. I have removed the cluster completely from the car because I'm stripping it. You don't have to do this to remove the dash top. This post has been edited by watsonrx13: Dec 14 2005, 08:08 PM Attached image(s) |
grasshopper |
Dec 18 2005, 06:57 PM
Advanced Member Group: Members Posts: 2,613 Joined: 10-December 04 From: Valdosta, GA Member No.: 3,258 Region Association: None |
next, remove the fresh air control unit in the dash. There are two ...8mm? nuts holding the cables to it, and a 10mm nut holding it to the body. Pull it out the front. Next, remove the steering column: there are four 7mm allen bolts holding it to the body
Attached image(s) |
