Fuel supply Hose ID, I think I'm starving it for gas |
tommy914 |
Dec 20 2005, 01:49 PM
Life is a journey, enjoy every turn. Group: Members Posts: 1,103 Joined: 15-September 03 From: Ridgeland, MS Member No.: 1,165 Region Association: None |
I would check AirCooled.net for a larger Weber needle and seat if you think that is what is constricting the system.
Joe Ricard |
Dec 20 2005, 06:09 PM
Well I started withthe easy stuff. inspecting the routing of hoses in the engine compartment.
One possible culprit (MAYBE) was the loop and droop ofthe supply hose to the regulator. So I got it straightened out. time and heat make the radious tighter. Second I replaced the regulator with a "T" I found one of my early mistakes or maybe just an over sight. the inlet fitting to the regulator were 1/4" ID I had it on my list to get better ones but somehow dropped track on that one. Carbs are not running over but.... are not running the same as before @ idle Which means I might be on the high edge of fuel pressure. Gauge got ruined in the storm so I need to get another one. Have I mentioned lately how much Hurricanes SUCK. |
Lo-Fi Version | Time is now: 30th April 2024 - 05:48 AM |
