Is there center console wiring in all dash's, adding center console with gauges. |
pnewman |
Dec 19 2005, 08:14 PM
Member Group: Members Posts: 371 Joined: 15-February 05 From: Lincolnshire, IL Member No.: 3,606 Region Association: Upper MidWest |
(IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) Hi all! (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif)
I was wondering if anyone knows if all porsche 914's have oem wiring to support adding a center console with gauges? I recently added the stock foglights utilizing all existing oem wiring after tracking down an oem switch. Is there wiring for the center console aswell ? thanks as always, (IMG:http://www.914world.com/bbs2/html/emoticons/pray.gif) your humble student, (IMG:http://www.914world.com/bbs2/html/emoticons/pray.gif) Pete (IMG:http://www.914world.com/bbs2/html/emoticons/beer.gif) |
Aaron Cox |
Dec 19 2005, 08:15 PM
73+ all have the wiring laying under the carpet next to da shifter....
pnewman |
Dec 19 2005, 08:31 PM
That's good news as mine is a 1974! (IMG:http://www.914world.com/bbs2/html/emoticons/clap.gif)
I know that ground is brown. What are the others? i.e. lights clock voltmeter other gauge (s) psi / temp? |
Ray Warren |
Dec 19 2005, 08:38 PM
Member Group: Benefactors Posts: 415 Joined: 1-October 03 From: Canada Member No.: 1,214 Region Association: None |
74 should be this.
Attached thumbnail(s) |
wilchek |
Dec 19 2005, 08:50 PM
Senior Member Group: Members Posts: 506 Joined: 8-June 04 From: Eastern Pennsylvania Member No.: 2,177 |
check this out. Also need a new heater lever with the center cluster. The handle is straight instead of bent.
http://www.pelicanparts.com/techarticles/9...ter_console.htm |
Aaron Cox |
Dec 19 2005, 09:28 PM
bassackwards... console lever is bent.... stock is straight |
Lo-Fi Version | Time is now: 30th April 2024 - 07:35 AM |
