1970 911 & 197X 914 any common parts? |
GaroldShaffer |
Dec 19 2005, 08:52 PM
You bought another 914? Group: Benefactors Posts: 7,620 Joined: 27-June 03 From: Portage, IN Member No.: 865 Region Association: None |
I have a line on a 1970 911 roller (read real cheap) that I just can't pass up (IMG:http://www.914world.com/bbs2/html/emoticons/cool.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/screwy.gif) So what parts are common between this 911 and any 914/4 or /6? I know the front suspension is a bolt on to a 914 anything else?
Now the roller is just that, no motor, trans, glass, most of the interior is gone. |
type47 |
Dec 19 2005, 08:55 PM
hood badge? (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif)
Joe Ricard |
Dec 20 2005, 08:05 AM
5 lug and vented front brakes?
Wiring harness for spare correct colored wire and switches connectors. Good fenders are good for resale as is anything else left over. |
Bleyseng |
Dec 20 2005, 08:18 AM
still a 901 tranny isn't it?
gauges swap over wheels swap over |
IronHillRestorations |
Dec 20 2005, 09:28 AM
Engine lid latch is the same (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif)
Front a-arms are 914. The early 901 trans is desireable for some 6 converters, but you have to flip the ring and pinion. IIRC vintage racers may also be interested in the trans. |
Aaron Cox |
Dec 20 2005, 10:34 AM
without the trans.... (some gud gears....)
its just a 911 front end with a whole lotta crap that ya gotta throw away later.... |
Phoenix-MN |
Dec 20 2005, 11:21 AM
Senior Member Group: Members Posts: 927 Joined: 23-January 04 From: ST. Bonifacius,MN Member No.: 1,590 |
911 emergency/parking brake assembly, vented rotors and larger rear calipers.
914Sixer |
Dec 20 2005, 01:37 PM
914 Guru Group: Members Posts: 8,871 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
The rear hubs are good for 5 bolt rear conversion if you use 6 stub axels. The relay board has a round unavailable tach balast for the 6 relay board. The 3 pin cdi box if it is any good works for 6's.
Lo-Fi Version | Time is now: 30th April 2024 - 09:04 AM |
