3 Pages V < 1 2 3 >
> Fuel Hose and linkage Routing for dual carbs, Show me your setup
maf914
post Dec 21 2005, 08:06 AM
Post #21
Not a Guru!
Wow, I can't believe the flat 12 in Paul's pic is cantilever mounted to a standard Porsche engine stand! (IMG:http://www.914world.com/bbs2/html/emoticons/ohmy.gif)
rhodyguy
post Dec 21 2005, 09:45 AM
Post #22
best linkage on the market in my book. expensive? a little. worth it? i haven't touched my carbs in a year and 1/2. disregard the bungee cord.
k
jr91472
post Dec 21 2005, 10:07 AM
Post #23
"I'm pacing myself sergeant..."
Thanks for starting this thread. I am in the same process right now.
Question to all: is there any advantage to which way the carbs face? Specifically, having cross-bar closest to the cockpit vs closest to the trunk? I've seen picture of both installs.
hope this isn't a hijack
(IMG:http://www.914world.com/bbs2/html/emoticons/beer.gif)
rhodyguy
post Dec 21 2005, 10:10 AM
Post #24
forgot to add mine is a triad. i never understood putting the bar on with the works on the rear.
k
Carlitos Way
post Dec 21 2005, 10:18 AM
Post #25
I did it MY WAY
I really dig this linkage:
rhodyguy
post Dec 21 2005, 10:29 AM
Post #26
look are where the drop links are positioned in that picture (under the rear lid? (IMG:http://www.914world.com/bbs2/html/emoticons/ohmy.gif) ). you have to stand on your head to dial the carbs in. what keeps the bar centered? a couple of springs?
k
Aaron Cox
post Dec 21 2005, 10:53 AM
Post #27
Professional Lawn Dart
QUOTE (rhodyguy @ Dec 21 2005, 09:29 AM)
k
ive had mine on the rear before... PITA like kevin said.
Kev - the CB setup is self centering. it has springs in each end....
Kargeek
post Dec 21 2005, 11:37 AM
Post #28
Having the arms to the rear is no big deal... you set it up properly once and that's it. More time is spent adjusting fuel mixture and synchronizing both carbs... then adjust your drop links to fit with the throttle arms horizontal without any side to side preloading of your final carb set up.
It also makes for neatly routing the stock length throttle cable.
Yes, the arms are centered with springs in each end of the bar.
The only issue with arms to the rear is if you have a tall mount linkage - it may interfere with the trunk torsion bars- mine are gone as I’m using 944 rear hatch shocks.
DH
Carlitos Way
post Dec 21 2005, 12:11 PM
Post #29
I did it MY WAY
QUOTE (Kargeek @ Dec 21 2005, 09:37 AM)
DH
Where did you get that mounting bracket for the throttle cable? That is AWESOME!!!
Aaron Cox
post Dec 21 2005, 12:14 PM
Post #30
QUOTE (Carlitos Way @ Dec 21 2005, 11:11 AM)
DH
he made it.
looks like 18ga, a little dremel, and a set of vice grips to fold it, and a drill...
Eddie Williams
post Dec 21 2005, 12:52 PM
Post #31
I planed on using the Aeromotive A1000 Bypass regulator for my setup, any thoughts??
http://216.242.145.16/products/product.phtml?p=20
Aaron Cox
post Dec 21 2005, 01:59 PM
Post #32
QUOTE (Eddie Williams @ Dec 21 2005, 11:52 AM)
-10 feed????? thats the size of my front oil cooler lines....
way too big i think.
jhadler
post Dec 21 2005, 02:32 PM
Post #33
Long term tinkerer...
QUOTE (Eddie Williams @ Dec 21 2005, 10:52 AM)
An-10 feed?!?! Good grief, this is a 914 we're talking about, not a top fuel drag car...
Way overkill. You'll need one seriously hefty pump to deliver enough fuel at enough pressure if you use -10 lines...
-Josh2
Kargeek
post Dec 21 2005, 04:34 PM
Post #34
[/QUOTE]Where did you get that mounting bracket for the throttle cable? That is AWESOME!!!
Yes, I made it- 18 years ago. You can make one too. Some scrap metal, cardboard template (I'm big on templates) , hacksaw, drill, grinder and files. It got thrown into all of the parts that got cad plated.
Eddie Williams
post Dec 21 2005, 05:03 PM
Post #35
indeed, quite large
as my feed is -6 can I just use a -10 to -6 union adapter? and a -8 to -6 on the return? and then -6 to each weber?
Aaron Cox
post Dec 21 2005, 05:04 PM
Post #36
QUOTE (Eddie Williams @ Dec 21 2005, 04:03 PM)
indeed, quite large
or buy the right one to begin with and be money ahead.
mallory makes a great regulator WITH return
Eddie Williams
post Dec 21 2005, 06:07 PM
Post #37
QUOTE (Aaron Cox @ Dec 21 2005, 05:04 PM)
ok, smart a$$... All my research for a FP Regulator with bypass pointed to this... I'll check out the mallory, is it all -6??
Eddie Williams
post Dec 21 2005, 08:15 PM
Post #38
the Mallory has -8 lines so i'd stll have to buy fittings...
Aaron Cox
post Dec 21 2005, 08:35 PM
Post #39
QUOTE (Eddie Williams @ Dec 21 2005, 07:15 PM)
Mallory with return...
use these fittings...
(IMG:http://www.jegs.com/images/photos/6504207.jpg)
Eddie Williams
post Dec 21 2005, 08:51 PM
Post #40
How do I get -6 fuel line to screw onto that? (IMG:http://www.914world.com/bbs2/html/emoticons/huh.gif)
3 Pages V < 1 2 3 >
- Lo-Fi Version Time is now: 11th July 2025 - 04:18 AM
