oil filter adapter gasket?, substitutes? |
3liter914-6 |
Dec 20 2005, 05:32 PM
Master of Clueless Posts Group: Benefactors Posts: 310 Joined: 12-October 03 From: State College, PA Member No.: 1,238 Region Association: MidAtlantic Region |
Hi,
I'm swapping a different engine into my brother's car over this week, and I've got an old gasket without a replacement. It's the think gasket that goes between the case and the arm for the oil filter. I've called around, and it looks like it's only available as part of a rebuild kit, and I was wondering what everyone does. It's mostly intact, so I'm planning on just tracing it and cutting it out on some gasket material, but if there's a better way of sealing it up, I'm all ears. Thanks! |
SLITS |
Dec 20 2005, 07:00 PM
Do as you said out of new gasket material....
Spread a thin coat of black silicone seal on both sides and bolt 'er up....... |
Jake Raby |
Dec 20 2005, 07:51 PM
or use loctite 518 "Gasket eliminator" and don'teven worry about the gasket...
3liter914-6 |
Dec 20 2005, 08:18 PM
I wondered if there wasn't a supergoop in the loctite lineup that'd be acceptable for this use. Thanks Slits and Jake. I probably won't be able to source the loctite in my timeframe, so I'll go the roll-your-own gasket route. I assume something like the Hylomar HPF would work pretty well on the gasket also? |
Lo-Fi Version | Time is now: 16th May 2024 - 07:39 PM |
