Adjustable Brake Bias Valve, experiences? installation? |
brant |
Dec 22 2005, 12:43 PM
914 Wizard Group: Members Posts: 11,632 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
All right... let me clarify my statement. When FIRST starting out and trying to get a rough estimate I still recommend tuning on a dirt road. I did it by having a 2nd party stand outside the car and making slow passes in a straight line at only 15 to 20mph I did it by making sure that I was not getting rear lock up first. Then after getting my rough settings, I moved to the race track and did fine tuning. I understand the concern about weight transfer. but I really didn't want to test my rough settings at 80miles per hour. Once on the old race car I had things set a little too close and actually had just changed race pads which upset the balance. I was on the back straight at 2nd creek in 4th gear at over 100mph when the rears locked up first. I went off the track and down into a good sized drop off at 80mph BACKWARDS! (luckily I only tore off the brake ducts, and didn't damage anything else except my pride) Really created a lack of trust on my part in the braking zone of that straightaway for the entire rest of the weekend. This is why I advised tuning on a dirt road at a SLOW speed. Yes there is overall less weight transfer, but there is overall less grip on all 4 wheels too. you won't be able to fine tune the set up, but you can get it roughly set at alot safer speed brant |
jhadler |
Dec 22 2005, 03:51 PM
Long term tinkerer... Group: Members Posts: 1,879 Joined: 7-April 03 From: Lyons, CO Member No.: 529 |
I jsut talked with a frined of mine who said that the lever type valve (Tilton) has a very narrow range of adjustment, and that at full open already yields a 50% pressure reduction, and full closed goes up to only 75 % reduction. Seems like a bogus design...
Anyone else with direct experience with these Tilton valves? |
JWest |
Dec 22 2005, 04:39 PM
Here is the Tilton chart: Attached image(s) |
Lo-Fi Version | Time is now: 3rd June 2024 - 03:58 AM |
