> You might own a leakdown tester and not know it
airsix
post Aug 24 2003, 10:46 PM
I have bees in my epiglotis
Do you have an air compressor with a pressure regulator?
Do you own a compression guage with a quick disconnect at the guage end of the hose?
I just discovered that if I do the following I have a free leakdown tester.
1. Set the compressor regulator to 100psi
2. Remove the guage from compression tester (quick disconnect)
3. Use tire valve stem tool to remove check-valve from hose.
4. Thread compression tester hose into desired cylinder sparkplug hole (at TDC)
5. Connect compression tester hose to air supply.
6. Read pressure on regulator gauge. Subtracted from 100 = leakdown percentage.
Congratulations on saving $85.
The bad news is the six I just tested has about 18% leakage (bad valves).
-Ben M.
- Lo-Fi Version Time is now: 12th July 2025 - 06:43 AM
