Rear traling arm/mount questions, racer-gurus, comment! |
Brando |
Jan 8 2006, 02:33 PM
Friday I dropped the teener off for new tiars and 4-wheel alignment. My rear-right is having issues matching the rear-left. At first I thought I may have a bent trailing arm, but Aaron and I think that the part where the trailing arm meets up to the ears/mounts may be ovaled out on the passenger's side, in-board towards the engine.
My understanding is that you just weld it up and drill a new hole that's the right size, then have it re-aligned... But I don't want it to oval out again. Is there some sort of extra bracing or support I can put in there to prevent this... without having to swap my rear traling arm or machine it. Does anyone have some small bent pieces of 1/8" or ΒΌ" steel that I could weld right in there for extra support? I plan on dropping the engine within the next month or two for a 1911cc conversion and I've got a shitlist a mile long for "while i'm in there"... But this might be a major issue if left un-attended, and I would like to prevent it from happening again. Any suggestions are apprecieated... except for cutting it out and going with a complete monoball/heim join setup with custom traling arms ... i plainly don't have the cash for that-- as enticing as it is. Thankyous! |
Lo-Fi Version | Time is now: 17th May 2024 - 09:38 AM |
