OT: Peter Egan quotes, gems from the master |
reverie |
Jan 9 2006, 04:36 AM
Senior Member Group: Members Posts: 783 Joined: 14-March 03 Member No.: 427 Region Association: None |
HAMMER: Originally used as a weapon of war, the hammer nowadays is used as a kind of divining rod to locate expensive parts not far from the object we are trying to hit.
MECHANIC'S KNIFE: Used to open and slice through the contents of cardboard cartons delivered to your front door; works particularly well on boxes containing seats and motorcycle jackets. ELECTRIC HAND DRILL: Normally used for spinning Pop rivets in their holes until you die of old age, but it also works great for drilling mounting holes in fenders just above the brake line that goes to the rear wheel. PLIERS: Used to round off bolt heads. HACKSAW: One of a family of cutting tools that transform human energy into a crooked, unpredictable motion; the more you attempt to influence its course, the more dismal your future becomes. VISE-GRIPS: Used to round off bolt heads. If nothing else is available, they can also be used to transfer intense welding heat to the palm of your hand. OXYACETYLENE TORCH: Used almost entirely for lighting various flammable objects in your garage on fire. Also handy for igniting the grease inside a brake drum you're trying to get the bearing race out of. WHITWORTH SOCKETS: Once used for working on older British cars and motorcycles, they are now used mainly for impersonating that 9/16 or 1/2 socket you've been searching for. DRILL PRESS: A tall upright machine useful for suddenly snatching flat metal bar stock out of your hands so that it smacks you in the chest and flings your beer across the room, splattering it against that freshly painted part you were drying. WIRE WHEEL: Cleans rust off old bolts and then throws them somewhere under the workbench with the speed of light. Also removes fingerprint whorls and hard-earned guitar calluses in about the time it takes you to say, "Ouch...." HYDRAULIC FLOOR JACK: Used for lowering a motorcycle to the ground after you have installed your new front disk brake setup, trapping the jack handle firmly under the front fender. EIGHT-FOOT-LONG 2X4: Used for levering a motorcycle off a hydraulic jack. TWEEZERS: A tool for removing wood splinters. PHONE: Tool for calling your neighbor to see if he has another hydraulic floor jack. SNAP-ON GASKET SCRAPER: Theoretically useful as a sandwich tool for spreading mayonnaise; used mainly for getting dog-doo off your boot. E-Z OUT BOLT AND STUD EXTRACTOR: A tool that snaps off in bolt holes and is ten times harder than any known drill bit. TIMING LIGHT: A stroboscopic instrument for illuminating oil buildup. TWO-TON HYDRAULIC ENGINE HOIST: A handy tool for testing the tensile strength of ground straps and brake lines you have forgotten to disconnect. 1/2 x 16-INCH SCREWDRIVER: A large motor mount prying tool that inexplicably has an accurately machined screwdriver tip on the end. BATTERY ELECTROLYTE TESTER: A handy tool for transferring sulfuric acid from a car battery to the inside of your toolbox after determining that your battery is dead as a doornail, just as you thought. AVIATION METAL SNIPS: See hacksaw. TROUBLE LIGHT: Its main purpose is to consume 40-watt light bulbs at about the same rate that 105-mm howitzer shells might be used during, say, the first few hours of the Battle of the Bulge. More often dark than light, its name is somewhat misleading. PHILLIPS SCREWDRIVER: Normally used to stab the lids of old-style oil cans and splash oil on your shirt; can also be used, as the name implies, to round off Phillips screw heads. AIR COMPRESSOR: A machine that takes energy produced by a power plant 200 miles away and transforms it into compressed air that travels by hose to a pneumatic impact wrench that grips rusty bolts last tightened 60 years ago by someone in Springfield, and rounds them off. |
70Sixter |
Jan 9 2006, 08:55 AM
Member Group: Members Posts: 422 Joined: 3-August 04 From: Surf City, NC Member No.: 2,444 Region Association: South East States |
Glad to see posting about The Master. My favorite part of R&T.
Nobody else can weave a story with a guitar, a 356 and a Caddy into a story about the Blues as he does. My knucles almost bleed when he restores a car. (IMG:http://www.914world.com/bbs2/html/emoticons/smiley_notworthy.gif) |
jim912928 |
Jan 9 2006, 09:39 AM
Senior Member Group: Members Posts: 1,485 Joined: 8-January 04 From: Granger, IN Member No.: 1,536 Region Association: Upper MidWest |
I needed a good laugh today...thanks for posting that. It is the first thing I read when my R&T arrives (usually the only article I actually read end-to-end).
flesburg |
Jan 9 2006, 10:14 AM
Senior Member Group: Members Posts: 506 Joined: 22-November 04 From: Pontiac, IL Member No.: 3,162 |
(IMG:http://www.914world.com/bbs2/html/emoticons/agree.gif)
We should all tell Peter Egan, that if he started his own newsletter, we would buy it and stop buying Road & Track. Peter is about the only reason I subscribe to the magazine, and he is from Wisconsin!, where they have about 3 months of each year to drive something other than a snowmobile. The only problem with Peter is that he likes English cars, and has now even joined the rank of mini-owners. Of course I want one too..Just like the attached... Oh, yes there is a Mini in the picture! Go figure Attached image(s) |
70Sixter |
Jan 9 2006, 02:24 PM
(IMG:http://www.914world.com/bbs2/html/emoticons/agree.gif) But where's the Mini? (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) |
reverie |
Jan 9 2006, 06:05 PM
Healthy girl.. (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif)
A recent Egan quote seen on automotive and motorcycle forums is: "Racing makes heroin addiction seem like a vague wish for something salty." Racing is a serious addiction, and there is no cure.. just a maintenance program. (IMG:http://www.914world.com/bbs2/html/emoticons/laugh.gif) |
Lo-Fi Version | Time is now: 9th May 2024 - 12:51 PM |
