Cleaning up my tranny, What is the best oil? |
DNHunt |
Jan 16 2006, 08:25 AM
Well that was pretty entertaining. (IMG:http://www.914world.com/bbs2/html/emoticons/popcorn[1].gif) We need a grenade smilie.
Dave |
sk8kat1 |
Jan 16 2006, 12:40 PM
Senior Member Group: Members Posts: 911 Joined: 10-October 05 From: belvidere ,IL Member No.: 4,937 |
ok I went to PP and saw the swepco -- 45.00 for a gallon -- so how is needed to do a change out ?
opera guy |
Jan 16 2006, 02:50 PM
Member Group: Members Posts: 337 Joined: 28-June 04 From: upland, ca Member No.: 2,268 |
word! i use the no-name stuff at FLAPS. black plastic bottle, dont remember the name. i think it works better then the swepco that was in it. when the swepco came out, it was clean. no metal shavings or anything. i just put the FLAps gear oil 90 or 95 weight. |
blitZ |
Jan 16 2006, 03:26 PM
Beer please... Group: Members Posts: 2,223 Joined: 31-August 05 From: Lawrenceville, GA Member No.: 4,719 Region Association: South East States |
2.6 quarts, as i recall. |
sk8kat1 |
Jan 16 2006, 03:51 PM
ok .. I see the plug on the trans to fill it and drain it -- according to haynes manual ... but does it really completely drian from that upper plug ?! .... and how the hell do you refill in the hole and see how much is really in there ?!
(IMG:http://www.914world.com/bbs2/html/emoticons/huh.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/confused24.gif) |
Jan 16 2006, 07:45 PM
914 Idiot Group: Members Posts: 14,991 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California |
First, you remove the upper plug. That's the fill hole. Always remove it first, just in case.
Next, you remove the lower plug. That's the drain hole. Make sure to have a drain pan under it! When the transmission is done draining, put the lower plug back in. Then fill the transmission up until the fluid is even with the bottom of the fill hole. Then you can put the fill plug back in. As for how, there are a number of ways. A funnel and a lot of clear vinyl tubing is a very messy way of doing it. There are also big one-quart syringe things that some parts stores sell. There are also hand-pumps that some stores sell, and those are the ones I like. They screw onto the tops of the one-gallon bottles. (Other versions screw onto one-quart bottles, if you're using those instead.) --DD |
Jan 16 2006, 07:55 PM
Resident German Group: Admin Posts: 41,681 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
(IMG:http://www.914world.com/bbs2/html/emoticons/agree.gif) |
Jan 16 2006, 07:57 PM
(IMG:http://www.914world.com/bbs2/html/emoticons/agree.gif) (again) the screw on hand pumps are the way to go. makes an oilchange a piece of cake. (IMG:http://www.914world.com/bbs2/html/emoticons/cool_shades.gif) Andy |
dmenche914 |
Jan 16 2006, 11:22 PM
Senior Member Group: Members Posts: 1,212 Joined: 27-February 03 From: California Member No.: 366 |
drain it when warmed up, drive it around first to get it hot. As per the other dave, take out the filler first, just in case it is stuck, better to not drain it if you can't fill it right? drain is on bottom of tranny, and shuold get most the juck out, just be sure to warm it up,a nd start it draining before amy particles settle down in the oil (ie don't wait, drain it right after driving.)
IanStott |
Jan 17 2006, 01:57 AM
Member Group: Members Posts: 226 Joined: 13-June 04 From: Moncton,New Brunswick,Canada Member No.: 2,199 |
Well since mine is out of the car and on the floor it will be easy to fill and drain, won't be able to warm it up though. Thanks to all who replied!
Ian Stott |
Bleyseng |
Jan 17 2006, 08:50 AM
Aircooled Baby! Group: Members Posts: 13,035 Joined: 27-December 02 From: Seattle, Washington (for now) Member No.: 24 Region Association: Pacific Northwest |
If its out of the car, atleast replace the front mainshaft seal! That is where they leak besides the o ring on the speedodrive.
(IMG:http://www.914world.com/bbs2/html/emoticons/popcorn[1].gif) |
Tobra |
Jan 17 2006, 09:33 AM
Senior Member Group: Members Posts: 1,453 Joined: 22-August 05 From: Sacramento, CA Member No.: 4,634 |
Sure you can, just set it in the vicinity of a space heater, just not too close. I have used regular Valvoline 90W gear oil in all my A/C VW for 25 years, and it is what is in my 914. Yellow metal does not like sulfur or synthetics much. |
Lo-Fi Version | Time is now: 11th June 2024 - 10:14 AM |
