NPC: problems with the jeep ... |
Jan 18 2006, 04:54 PM
Resident German Group: Admin Posts: 41,623 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
for the last couple of weeks i have this odd problem with my '93 jeep wrangler ...
you know when you're in 4-wheel drive and you drive around a tight (low speed) corner how your wheels "wobble" and make noise as they skid because of the locked differential ... well, that's perfectly normal for 4-wheel drive, but lately, the car does the same in 2-wheel drive! (IMG:http://www.914world.com/bbs2/html/emoticons/wacko.gif) and on top of that, the front-end feels "lose". mushy. like the sway bar is broken (which is not, i checked that). anyone got any ideas? (IMG:http://www.914world.com/bbs2/html/emoticons/confused24.gif) Andy |
rick 918-S |
Jan 18 2006, 04:58 PM
Hey nice rack! -Celette Group: Members Posts: 20,443 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region |
U-joints, or steering ball joints. Why do you have it in 4 wheel drive in the land of sunshine? (IMG:http://www.914world.com/bbs2/html/emoticons/cool_shades.gif)
Jan 18 2006, 05:00 PM
well, i *do* take it off road sometimes, and in the "winter" here, off road means "muddy mess" ... on the road, it's always 2-wheel drive. except, now the tight corners feel like i'm still in 4WD ... (IMG:http://www.914world.com/bbs2/html/emoticons/huh.gif) Andy |
rick 918-S |
Jan 18 2006, 05:05 PM
The drive axles are still turning. So the u-joints are still turning. There is a gizmo inside the right side of the diff that slides over the axle stub to lock in the 4 wheel drive. So when you turn whether you have it in 4 wheel or 2 wheel the joints are still turning. If their bad they clunk, clunk, clunk.
Root_Werks |
Jan 18 2006, 05:18 PM
Village Idiot Group: Members Posts: 8,315 Joined: 25-May 04 From: About 5NM from Canada Member No.: 2,105 Region Association: Pacific Northwest |
Jeeps use a vacumm operated locker. It is a little arm on the pass side of the front axle. Probably stuck. Lube it. Move it around, lube again.
Sometimes if you turn lock to lock going like 5mph it will free up as well. Old simple system. (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif) |
Root_Werks |
Jan 18 2006, 05:19 PM
Yeah, what he said. (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif) |
messix |
Jan 18 2006, 06:26 PM
AKA "CLUTCH KILLER"! Group: Members Posts: 6,995 Joined: 14-April 05 From: between shit kickers and pinky lifters/ puget sound wa.north of Seattle south of Canada Member No.: 3,931 Region Association: Pacific Northwest |
i second that. the dog clutch on the front axel sounds like it stuck. also jack one side up and spin wheel, check the wheel bearing [unit bearing, when they fail they fail bad wobble ,noise, and all that. do you have a locker in the front?
and verify transfer case is in 2wd[stupid queastion but allways worth shifting from 2wd to nuetral and back]. |
Crazyhippy |
Jan 18 2006, 07:01 PM
Insert witty comment here... Group: Members Posts: 1,659 Joined: 28-July 05 From: Home of the Coyotes, AZ Member No.: 4,493 Region Association: None |
The actuator on the passenger side of the front axle is vacuume actuated. Check the lines on it.
Also try to spin the front Drive shaft, it should be free to turn. The transfer case not kicking back into 2wd due to tweaked linkages will make the Jeep act like it's in 4wd too. BJH |
bd1308 |
Jan 18 2006, 07:09 PM
he vac lines on my 94 were old, and sometimes it wouldnt kick back into 2wd or something.
i drove like normal and it eventually popped-out. b |
Gint |
Jan 18 2006, 07:55 PM
Mike Ginter Group: Admin Posts: 16,070 Joined: 26-December 02 From: Denver CO. Member No.: 20 Region Association: Rocky Mountains |
Actually, the later Cherokees and I would assume the Wrangler's (since they used the same front axles for the most part) were not vacuum disconnect. My 93 XJ was not for sure.
bd1308 |
Jan 18 2006, 07:56 PM
1000% positive mine was....
check the magazines for the aftermarket Jeep parts, they list the cable unlocker for all YJs...Posi-Trak i think its called. Its vasc disconnect for sure. b |
Gint |
Jan 18 2006, 07:57 PM
Oops! My search through my Jeep email archives revealed a thread indicating the following:
"The yj was still using the disconnect system in 95 as the xj was not." So appraently the YJ was vacuum disconnect in 93. That could very well be your problem. Those vacuum manifolds at the axle are plastic and tend to break and crack (surprise!). I helped a girl at work replace one on her 88 Cherokee. I eventually bought that same Jeep. My oldest is driving it back and forth from CSU in Ft. Fun. |
Jan 18 2006, 08:01 PM
thanks for the leads guys (IMG:http://www.914world.com/bbs2/html/emoticons/smilie_pokal.gif)
i'll check tomorrow, provided it stops raining for an hour or so. i hate lying on my back under the car in the rain ... (IMG:http://www.914world.com/bbs2/html/emoticons/wacko.gif) Andy |
Gint |
Jan 18 2006, 08:02 PM
IIRC, that manifold can be had from Jeep for $30-40 clams. Sometimes the hoses just come loose. Or on of the hoses cracks and breaks.
bd1308 |
Jan 18 2006, 08:05 PM
some of my offroading buddies used to shear/tear/snag those hoses on rocks... |
Gint |
Jan 18 2006, 08:43 PM
Ya, I know.
Gone but not forgotten. Attached image(s) |
bd1308 |
Jan 18 2006, 08:46 PM
I traded my rust-free 100% running jeep for my piece 914....
sigh...... bro has it now..... b |
rezron |
Jan 18 2006, 10:59 PM
Member Group: Members Posts: 327 Joined: 25-December 02 From: Mason City, Iowa Member No.: 10 |
Did you check the steering stabilizer(shock) on the front axle? I had that go out on a '92 cherokee and it did what you're discribing. Good luck! rezron |
Jan 18 2006, 11:01 PM
ok,,,,duh... beat him up and get it back. |
bd1308 |
Jan 18 2006, 11:21 PM
uh, he has four wheel drive....
and i have a car that only starts on every three and a half keyturns. b |
Lo-Fi Version | Time is now: 7th May 2024 - 09:45 AM |
